2.2S VS 2.7 cylinders
Is there a way to look at the cylinders and tell the difference between 2.2S and 2.7? Can the correct 2.2 heads accomodate 2.7 cylinders?
Thanks in advance,
356robo
70 T Targa
Looking for a 2.2,2.4, or 89 coupe
Old 06-12-2005, 02:32 PM
trak ratt's Avatar
The 2.2 has an inside diameter of 82mm, and the 2.7’s is 90mm. 2.2 heads can be used but require modification. The combination of 2.2 stroke and 2.7 bore nets 2.5 liters. I have one of these equipped with e-cams and it makes for a sweet combination in an early car.
Some cause happiness wherever they go; others whenever they go.
Old 06-12-2005, 05:26 PM
