reducing weight=cheap horsepower
A drop in weight will give an equivelant in horsepower rise. Does anyone have an approximate formula?
Simon
85' Carrera 3.2 02' Mazda MX5 |
I remember 8lbs/hp being used as an approximation.
1980 911SC Targa 3.6L |
That's what I was thinking too, but for the life of me I can't put my hands on the reference. It's the location of the weight loss that's more intangible and harder to formulate, ie: 50 pounds off the roof is better than 50 pounds off the floor pan, at least in terms of handling.
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar. '11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX. Last edited by Wavey; 06-12-2005 at 04:17 AM.. |
12LBS. = 1HP I think. Check out rennlight.com for some good info. and comparisons.http://rennlight.com
ELVIS 84 CAB -SOLD Last edited by 84CAB; 06-12-2005 at 05:18 AM.. |
Doesn't it depend on the initial weight of your car?
'82 911SC racecar '05 WRX STi |
There is no one size fits all formula. It all depends on where the weight is. 1# at the tire is more significant than 1# at the wheel, is more significant than 1# at the hub, is more significant than 1# at the CoM.
1# at the front bumper is more significant than 1# at the rear bumper, is more significant than 1# at the CoM 1 g at the piston is more significant than 1g at the crank a few grams of engine speed reciprocating mass is more significant than 1# at the CoM Etc Etc Etc.....
If we assume as an exercise that the weight is applied at the CoM...
Check out http://rennlight.com/cgi-bin/hp.cgi
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Yes, that makes sense.
Thom that's interesting
and in line w/ figures I have seen elsewhere, the problem is there are lots of fudge factors involved especially at our budget levels
Thanks for the Rennlight connection and all the other variables. Not really that simple is it?
Simon
I've done some stuff to lighten my car which some might consider extreme, like a fiberglass roof and felt dash, but I've left some low-hanging fruit to pick up later, like removing undercoating and replacing my fenders and quarters with composites. In fact, just last weekend I picked up a set of carbon fiber front fenders, but I can't install them until I get my fuel cell installed, as they don't have a filler flap.
If the weight/horsepower discussion is only considering acceleration, then it is rather simple for non-rotating parts because it is lbs/hp that really matters. A decrease in weight will give approximately the same improvement in acceleration as a similar fractional increase in power. Going from 3000 lbs to 2800 lbs in a 200 hp car is equivalent to keeping the weight at 3000 lbs and increasing the power to 214 hp.
Of course, it really becomes a bit more complicated than that as the various replies above can attest to, and removing 200 lbs from a 3000 lb car will help cornering and braking, whereas adding 14 hp will not.
Mike '87 911 |
Ignore my post above -- it is correct, but has all been said before (probably many times!) This is what I get for being gone for a while and catching posting before checking all the unread posts...
Mike '87 911 |
Light weight is only "cheap" horsepower if you're removing stuff you decide you don't want. If you're replacing stuff with lighter stuff, that's usually expensive horsepower. If you're doing it that way, adding horsepower is usually cheaper than adding lightness. (And adding noise is cheaper still.)
