Back Fire when changing gear
Does anyone else get a little back fire when they are changing gear, say from 2nd to third under heavy acceleration? (by the way how good is that anyway! wayhay!!!)
Old 06-12-2005, 09:44 AM
durn for'ner
livi's Avatar
Sure do ! Makes me feel like driving a real race car !
Markus
Resident Fluffer
Carrera '85
Old 06-12-2005, 11:13 AM
Adrenaline Junkie
Hayabusa's Avatar
You're running rich.
Old 06-12-2005, 11:24 AM
Nitrometano's Avatar
But that looks great!!!
1972 911T
1991 Mazda RX-7 Turbo II
Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life!
Old 06-12-2005, 01:28 PM
Irrationally exuberant
ChrisBennet's Avatar
It's pretty common to get some popping under the conditions you describe when using a free flow exhaust like SSI's or B&B.
I don't know if it is because it leans things out or the lack of muffling lets you hear the pops you would get from existing exhaust leaks.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 06-12-2005, 02:48 PM
RETIRED
Joe Bob's Avatar
Most likely an exhaust leak at a flange...
2012 ML350 3.0 Turbo Diesel
Old 06-12-2005, 03:08 PM
Can be a portable Porsche B.B.Q.?
1972 911T
Old 06-13-2005, 08:13 PM
copper's Avatar
exhaust leak. I'd put money on it. Like was said, it's gonna be your flanges where the heat exchangers connect to the muffler.
Jim Dean LL.B. - London, Ont, Canada.
1969 911T "Blood Orange" Euro (Brought over from Germany in 86)
Engine and brake system rebuilds 2006 & 2007
"Oversteer scares passengers, understeer scares drivers."
Old 06-13-2005, 10:34 PM
dimps8's Avatar
Exhaust leak is only half your problem. You probably still have unburnt fuel entering the exhaust, mixing with the air sucked in on gear change/decel through a hole or bad join and bang! you need to fix both, Imo.
Damon Harris
66 912 coupe
Old 06-13-2005, 11:22 PM
Hald's Avatar
My '84 used to let out with a loud "pow" between shifts, under hard acceleration, typically at the track where it echoed off the barriers.
I only noticed it with a "test pipe" and Bursch muffler - not with the stock exhaust.
Mark
'77 Carrera 3.0
http://members.rennlist.com/hald
Old 06-14-2005, 04:41 AM
copper's Avatar
I've got no idea what your car is, so it's hard to tell you how to fix it. Let it idle and feel for escaping pressure around the exhaust flanges. If it's an early carburated car, they're pretty easy to set and balance if you get a synchrometer...
Old 06-14-2005, 07:05 AM
