Rotor and Cap question.
I replaced my ignition wires on Saturday and WOW, what a difference! Better everything! Anyways... When I took off the rotor cap I noticed the six copper contacts and the rotor "blade" had a dark gray/black residue which I guess is caused by friction over the years. Everything still works fine but I can't help but think the contacts should be clean. Would fine grain sandpaper be ok?
Thanks, nik.
1980 911 SC widebody, Black/Black. 1993 BMW M5. Silver/Black. |
You can try that as a temp fix but for the price of a cap and rotor ( under $20.00 ) in my opinion you should just replace them. You can keep the set you have as a emergency spare. I recently had an ignition miss on my car and replaced the cap and rotor, the old set I took off had what you describe on the cap and rotor,other than that they looked fine.
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
If you can feel (with your fingernail) a step in the contacts of the cap or rotor, its time to replace.
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
Thanks!
Also, when I replaced the wires I didn't replace the wire that comes out of the center of the rotor cap and attaches to the cylinder shaped unit directly above the rotor because I could not figure out how to remove the wire from the cylinder end of things, it doesn't just pull out. Thanks. nik.
