salvagable bilstein insert?
I took my sport inserts out today and one of them wouldn't come, so I used a pipe wrech, gently, to grabe the shock body just above the threads on the strut. I gave it just a little tug and off comes the green sleeve leaving the piston inside the strut and still stuck. I finally got it out with some 2x4's and a tiny jack. with almost no problem. So I have this left over, see pic, is it garbage or could someone use this? The other one is perfect. They only had 1700 miles on them. Being impatient will cost ya
Old 06-15-2005, 04:38 PM
Can't help on the insert, but it looks like someone finally found a use for Coors Light. What did you do with the beer?
Tim
1986 911 Cab
2008 Audi A6
Old 06-15-2005, 07:32 PM
Jeff Alton's Avatar
I am sure Bilstien can put them back together again for you, or maybe even send you some info. I have found them helpful on the phone many times in the past!
Jeff
www.turn3autosport.com
Old 06-15-2005, 09:24 PM
