ejames19's Avatar
Thumbs up Front end to high! How to lower?
Have searched the site for sometime and cannot find a descriptive enough thread on how to lower front end, the back of my car is nicely lowered, the front end I would like down about 2 more inches. If anyone can point me to a link, threads or explain what is needed to lower front that would be great.
'No illusion is more crucial than the illusion that great success & money buy you immunity from the common ills of mankind, such as cars that won't start.'
'81 911SC Coupe
'03 MDX
'00 328i
Old 06-15-2005, 06:59 AM
Friend of Warren
First you need to buy Wayne's "101 projects for your 911" which will show you how to not only adjust your suspension, but 100 other projects all with color pictures. To adjust your front suspension you will find a vertical bolt (either 10mm or 14mm) at the end of the torsion bar closest to the passenger compartment. Turning the bolt one way raises the car, the other way lowers. If you can't lower the car enough you will have to re-index the torsion bars.
Kurt V
Old 06-15-2005, 07:19 AM
Unregistered
sammyg2's Avatar
If you touch the height adjustment, you will have to have the alignment checked and adjusted. It is also very easy to corner-jack these cars, i.e. get more weight on one front wheel than the other. Not a good thing, scales are required to nail that unless you are very creative.
Lots O'folks play with that adjustment and then wonder why they can only get 3000 miles out of a set of tires, not to mention the adverse handling characteristics. My advice? find a local Porsche shop who does alignments, have them make the adjustments and do the alignment.
This is not something that average Joe should be messing with IMO.
Old 06-15-2005, 07:27 AM
And don't forget that lowering the car changes alignment. I believe it'll cause more toe in and increase negative camber so if you are chinging the front much you'll need a new alignment.
What is the measurement of the top end of the front wheel well lip and the rear wheel well lip? The rear should be roughly 1/2" lower than the front because the rear is cut differently than the front. With that measurement the car should have a roughly 1* rake.
Old 06-15-2005, 07:29 AM
ejames19's Avatar
Thanks for all the info. How much would a front end alignment cost or would I need alignment all around? Just want to compare cost. The measurement between front and back I can't get exact right now but it is definitely more than a few inches difference, the old PO looks like had the back end dropped and didn't adjust the front at all. Do want the front end down considerably might have to take it in as sammyg2 recommended to a shop.
'81 911SC Coupe
'03 MDX
'00 328i
Old 06-15-2005, 07:41 AM
Senior Member
Superman's Avatar
These cars are so light that corner balancing really is an issue. You can use DOT scales to get them very close, but alignment will change when ride height is changed. DOT scales are left on when the weigh station is closed. Sounds like you don't know whether the car is aligned at the moment or not. So, do all the stuff you're going to do (shock and tire changes, etc), and then get a pro alignment and corner balance. You'll pay a few hundred dollars.
The vertical bolt is neither a 10mm nor a 14mm. I think it might be a 12, but it's pretty easy to find, at the ends of the aluminum crossmember. May be an 11. Front fender lip should be 1/2" higher than rear, for the 1 degree forward rake.
Mocha 1978 911SC. "Coco"
Old 06-15-2005, 08:08 AM
DW SD's Avatar
Post a photo - you will have no shortage of opinions on proper ride height. Lowering the front is very easy, unless the torsion bar adjusters ran out of adjustment. Even then, it is only another 15 minutes per side (at least with an easy way to raise and lower the car).
BTW - a full corner balance and alignment can be $300 to $500 US.
It is a very iterative process.
Good luck!
1971 RSR - interpretation
Old 06-15-2005, 08:09 AM
ejames19's Avatar
Thanks all, I will post photo later tonight, again the back looks great, the front is just up a litttle in my eyes. Photo will be up in a few hours.
'81 911SC Coupe
'03 MDX
'00 328i
Old 06-15-2005, 08:25 AM
Yellowbird RS's Avatar
How loose can I run the bolt and how do I adjust the T-bars, my car looks like a Dakar cup.
X/A
Old 06-15-2005, 09:30 AM
ejames19's Avatar
Nice looking P!! Good question about how far you can turn. Hope one of the more knowledgeable ones will catch the question.
'81 911SC Coupe
'03 MDX
'00 328i
Old 06-15-2005, 09:53 AM
DW SD's Avatar
I don't have any photos to share. Picture is worth 1000 words. If you use the search function "torsion bar front adjust" or something to that effect, I'm sure you'll find plenty of photos. The adjuster bolt threads a long ways and can change ride height by a matter of inches. It is held tight by a threading compound, not through some torque spec. Look at the pictures, if you can find some and it'll make much more sense.
If your car is a 964 (Dakar cup car), it doesn't have torsion bars, instead it has coil-overs.
Doug
Old 06-15-2005, 09:58 AM
Unregistered
sammyg2's Avatar
One more thing to look at:
if your rear shocks are shot it will make the back squat down more than normal.
My car sat low in the back but when I installed new bilstein sports the back came up and now it looks too low in the front.
A full corner balance and alignment aint cheeep but it makes a huge difference. Make sure all components are good before having the corner balance done, no sense in having to do it twice.
If money is an issue you can get it close to ballpark with a tape measure and then have it aligned, but it won't be perfect.
Old 06-15-2005, 11:04 AM
KNS KNS is offline
sammyg2, I have heard also that the rear end will come up with new shocks. Do you remember how much (half inch - inch?)?
Kurt
Old 06-15-2005, 12:41 PM
Unregistered
sammyg2's Avatar
Well, before it looked like the rear was a little low, now it looks like the front is too low. See attached pictures for the before and after. The second picture is after the new shocks but I also raised the front 1/4", it was even lower before I did that.
So I would guess that the back came up at least an inch, probably 1 1/2".
But......... my left rear shock was completely blown and wasn't supporting the car much at all. The right rear was very weak.
If your shocks are in better shape then it would stand to reason that new shocks wouldn't make as much difference on your car.
Old 06-15-2005, 12:48 PM
Unregistered
sammyg2's Avatar
Also note that I have several hundred miles on the new shocks when that second picture was taken. Some people say the new shocks settle in and drop the car a little after driving it, I didn't see that happen at all on my car.
Old 06-15-2005, 12:55 PM
Sammy, Thanks for the input my car is a 74 Carrera w/some mods., I'm running new blistein HD all around and 23f, 29r mm., t-bars
I found it T-bars adj.
X/A
Old 06-15-2005, 01:53 PM
JBO JBO is offline
Beautiful car Sammy. Your ride height looked perfect in the first picture
Old 06-15-2005, 02:12 PM
Unregistered
sammyg2's Avatar
tanks (blushing)
Old 06-15-2005, 06:08 PM
450knotOffice's Avatar
Sam, did you get that corner balance you talked about last time we met?
Old 06-15-2005, 11:22 PM
BReyes's Avatar
I will measure mine tomorrow. I think you will like the setting. Last I thought about this, it was slightly lower than Euro height.
Regards,
Bernard
Old 06-16-2005, 01:23 AM
