Dear all,
I´am new in this board and therefore I want to give a short introduction of myself: My name is Kassen Oldewurtel and I live in the southern part of Germany (in the near of Stuttgart, as you know from BOSCH, PORSCHE and of course Daimler now w/o Chrysler). I own a ´87 3.2 l 911 convertible and a car for "normal use" (1.9 l Audi A4 Avant TDI) As I do all maintance on my cars by myself, I was asked to repair a CDI Box BOSCH "0 227 200 001" from a collegue of mine. Due to a wrong cabling the SCR was gone "into the semiconductor heaven". The original equipped type (AEG T6N500COB) is obsolete and not longer available. What is the suggested substitution with identical (or better ;)) electronic and mechanical (M6 stud) figures?? I took the TIC126N (appr. $2.00 each) in combination with a selfmade (turned and milled) adaptor. But this is a rather complex solution (pls see picture):D:D Regards Kassen http://forums.pelicanparts.com/uploa...1196013979.jpg |
Hello Kassel
do you like to use OEM design or the T-220? Use a 2N6509 as a T220 replacement Bob |
Hello HKZ Bob,
thanks for the reply, I would like the OEM Design with the M6 stud. Do you know a supplier or distributor for this part? Regards Kassen |
Kassen, that is a funny and ingenious design. But why bother to get an M6 style device in the first place. You could simply mount the TO220 housed device instead. Finding a TO220AB housed device with isolated mounting fin make it even easier.
Bob's suggestion is a part readily available in the U.S. but the TIC126 series seems equally suited. I can seem to find it from the U.S. suppliers but I remember that the TIC series is used in Europe quite often. TIC106 was what was used in old equipment for light controllers. The TIC126 seems to have all required ratings to surpass the original AEG device. As an interesting side note the TIC126 is listed on Conrad's website as an International Rectifier part. However, I don't think IR makes it. Does your box work after you put the TIC126 in? Cheers, Ingo |
Hi Ingo,
I tested the device on my workbench w/o ignition coil (it´s still in the car and therefore 35 km away....). I used a resistor (180 ohms) instead and looked at the output with a DSO. The box sounds terrible, but I think that´s normal :D:D. I was completely suprised to find the Test Manual and a (selfmade) circuit diagram in this board. I am able to see the red illuminated "BOSCH" sign in Stuttgart/Schwieberdingen from my kitchen window, where this box was developed, but no chance to get any information about this old stuff :confused:. The final test (in the car) is next week and I`am looking forward to this test (with TIC116 or TIC126). The TIC126 will arrive tomorrow. Greets Kassen |
Greetings, Kassen, from Texas!
Bosch test documents specifically say not to use a resistive load on the CDI unit ... only a proper coil! |
Sorry for this late answer.
I have used a 2N692 as a replacement (with the correct TO-48 case). I did it only once without problem even though this model is not specified for Toff. The 2N692A is specified with a Toff of 15 µs, if you can find it. Hope this help. |
hi at all!!
I am new here and I hope you can help me :) the big condensator 1 227 330 003 is shorted, does someone know what new element I could build in in stead of this? bosch says me that they don´t have it anymore. thank you very much! regards chris |
Lot of those parts are NLA, try contacting Loren or Ingo. Early S Man passed away a few years back.
It's good to see that Warren lives on in these forums.
Maybe someone who knows his family would like to contact and tell them as a sort of honor. |
the big condensator may easily be replaced with a metalized polypropylene condensator of the MKP family.
A MKP condensator of 1.5 µF 630 V is the correct value to choose and can be obtained from any electronic parts retailer. |
condensator...what is hell is that...?
"capacitor" is better, sorry.
Condenser, capacitor
Big round things inside the CD box. Quite available from electronics parts suppliers, you march the voltage and capacitance rating.
All the parts inside the box are available......not from Bosch, but out there in the electronics market. |
thank you very much for the info!
I will try to get it in a electronic shop! thanks! regards chb |
OK this info. is awesome! Working on Alfa Montreal Boxes same thing, Porsche has way better documentation than Alfa Romeo Guru's. Took this on as a challenge, It's FUN!! Well anyway I can figure out some of the Voltages but there are points indicated in the schematic (NUMBERS 1-8 some (A's) for voltage measurements and NO documentation on this anywhere. What gives? Can some one give a link or post on this. I'm doing this on the bench, Pulse Generator, Scope haven't broken out this stuff in years. It's a Blast. I'm going to eventually put one of these in a 4 cylinder Alfa to see what happens. Thanks for the HELP and the valuable information!
i really really really wish i could understand this, my CDI quitted working two days ago so i took it out to test it which i couldnt because im afraid ill make it worse
http://i267.photobucket.com/albums/i...na/photo-7.jpg best regards |
i dont se bearings or zero fittings so it's all voodoo stuff, pelican offers rebuild service, contact them.
Thanks Warren! |
Took on the challenge of fixing them this Winter. The mechanics is harder the the electronics.
I changed all the caps in the circuit including the Output Cap. The SCR is the ususal culpret. It the device in the lower right hole. Also as a precaution I change the 4 output Diodes, since there cheap. I've repaired 8 already and all work in real applications. All the components are replaceable and I have all the new part numbers. |
I have just installed an overhauled Bosch CDI box (ECUDoctors). The car started and ran normally until and "external" capacitor gave out. The capacitor is wired in parallel with the box and is located between terminals B and C: Power supply from ignition and breaker points. This capacitor is made by Marchal I believe and is NLA. It appears to be used for smoothing out power to the box. Is it still necessary with an overhauled box? My car is a 1973.5 911T which I've owned for 31 years.
Thanks, Doug |
Should not be connected between the breaker points and 12vdc. Try it without the cap.
B and ground or B and D would be more like it, and the cap should be 10,000 UF 25V electrolytic capacitor with + to B |
It is B and D, my bad. I recall one of the wires is brown and goes to the case on the box. The car runs fine without the cap. Is it really necessary? If it is necessary where would you recommend I get one since they're NLA? The car is currently at a friend's shop so I can't just go look at it. I'll be working on it Saturday. Thx.
It is not really necessary. Did not come stock with it.
It does smooth things out and and is especially important when you install an aftermarket CDI that puts out more power like the MSD or the Daytona-Sensors CD-1. It is also good for radio noise suppression. Here is one source of the cap Daytona Sensors LLC - CD-1 Capacitive Discharge Ignition System for Racing look at bottom of the page. I run one on my CD-1 setup. |
Many thanks for the link. My car is VERY stock and I'm trying to keep it that way. What does the capacitor look like and how big is it? The existing cap I had was about .625 diam x. 2.5 inches and was an aluminum can. $43 seems exorbitant when Digi-Key sells similar caps for about $2.50 - Unfortunately they don't stock them and minimum buy is 250!
Cap is about 3.5 inches tall and 1.5 ion in diameter. Comes with a bracket and screw terminals.
I would sho\p around to Mouser, Digikey eBay....etc. It is the type used in high end car audio installs to provide reserve power. With a stock Bosch CDI it may be overkill. With a modern high power CDI the there is a constant 12 vdc feed with a heavy gauge wire and a switched feed. The constant on can draw as much as 8 AMPs and it is recommended that you connect to the battery terminal on the starter in the 911, and use the Bosch CDI power as the switched power to turn on the CDI. It is recommended to use the cap in this installation to give some reserve power and avoid spikes. It also can help with radio interference. |
Will an MSD 8830 Capacitor from Autozone work? It's 26,000µF and it's sold by MSD for automotive applications. The cost is similar to what you've proposed?
that should work fine.
'd figure out why it was there in the first place. Does it run without it, like the cap was shorted?
Hi. Does anyone have similar information regarding 8 pins CDI box for a 1976 930?
Best regards Jesper |
Hi to all,
i 'm not the first and i will not the last that would like to fix our CDI. I need your help to find the correct parts, to avoid to make mistakes. I haven't the correct devices to check all the component (only a simple FLUKE) so my approach is to change all that i can, like a dummy... My CDI is 0 227 200 008 http://forums.pelicanparts.com/uploa...1414965437.jpg Resistors: Is it necessary to replace all to stay safe even if they are not interrupted? Capacitors: what is the alternative to WIMA FKC3 ? --> i have no idea :confused: Diodes: Is it necessary to replace all to stay safe even if they are not interrupted? ZD1= 1N3003B --> i found it :) (Thanks UGO) ZD2= 8ZY 85 / C6V8 --> i have no idea :confused: ZD3= ZM22 --> i have no idea :confused: T1 = RCA 2N3055 --> i found it T2=T4018 --> i found it T3=T4018 --> i found it SCR OT104 --> is TIC126N the state of art? Buy Thyristors SCR Thyristor TIC126N-S, 800V 7.5A 20mA, TO-220 3-Pin Bourns TIC126N-S online from RS for next day delivery. Graziehttp://forums.pelicanparts.com/suppo...s/boldblue.gif |
I would advise not to simply change all the parts. Find out what is damaged instead. Else I don't think the box will ever work again. I repaired several hundreds....
For instance the SCR you mentioned will not work, leave the original one in place unless it is shorted (rare but impossible, can be checked with the Fluke) - trust me. |
Is there a guide for fixing these? Kind of cdi for dummies on how to test the components, what are the usual faults to check for, and finally how to rebuild them? Im really interested
Thabks in advance |
Thank you ischmitz,
i've tried to measure the SCR (the model is T6N500COBm, and no OT104 as i wrote) and the resistence is very low (i think is shorted). http://forums.pelicanparts.com/uploa...1415051548.jpg http://forums.pelicanparts.com/uploa...1415051664.jpg Is it correct way to measure? I have another CDI from Alfa Montreal (in very bad condition), and the SCR is Motorola MAC40798 , the resistence is lower than other. http://forums.pelicanparts.com/uploa...1415051884.jpg http://forums.pelicanparts.com/uploa...1415052001.jpg Which is the correct replacement? |
I'm not sure that i worked in the correct way, so I try to measure from case to the pins
For T6N500COBm: from case to short pin the resistence is infinity, and the same is from case to long pin For MAC40798 the situation is different: from case to short pin i s 23.8 Mega Ohm from case to long pin is 23.7 Mega Ohm Marco |
Marco,
Remember the housing of the SCR is isolated from the heat sink, its the anode of the SCR. The critical measurement is from the long pin (cathode) to the case (anode). It should be infinite resistance regardless of polarity of your meter. The short pin is the gate. The gate/cathode is a PN junction and acts like a diode. If your meter is set to Ohm you might measure a value when you forward-bias the diode and infinite resistance when you swap the leads. Once you set you meter to the diode setting you need to see open in one direction and some voltage when reversing the leads. This is the forward voltage drop across the PN junction. It should be between 0.4V - 0.8V Ingo |
Hi ischmitz,
Thank you for your help. For both SCR, using diode setting, i have infinite resistence (0L) from cathode (using red tip of my Fluke) to anode (black). The measure of PN junction is 0.077 V for the first and 0.031 V for the second, so they are ready the garbage bin :( |
Sorry Marco,
I spoke too soon about what to expect for the measurements. And I am surprised I haven't been called out on it. Anyhow, the correct measurements are: Infinite between Anode and Cathode You will measure an ohm-like behavior between gate and cathode and so your observations are in line with a healthy SCR. However, you could still have issues. You might want to follow the instructions in the link here: How to test an SCR - Electronic Circuits and Diagram-Electronics Projects and Design to get a quick functional test. Then even with these tests passing an SCR can become marginal with age in that it doesn't perform properly once at elevated temperatures. This will only become apart in a functioning CDI box on a test stand. My recommendation is to not change it and correct whatever other issues there are with the box and then operate it. This will be the final test for the SCR. Regards, Ingo |
ischmitz...
You're knowledge of these is evident, I have a friend who is incredible with electronics, but not 100% versed in CDI boxes (mine is a 6 pin). Upon opening we found the large capacitor toasted, completely open, and one of the wires arched to it. If we can't get our brains around it, are you open to working on these still? Sauce |
| All times are GMT -8. The time now is 12:45 PM. |
