-   -   History of Bosch CDI ... toubleshooting info, parts list changes, and schematics ... (http://forums.pelicanparts.com/porsche-911-technical-forum/226517-history-bosch-cdi-toubleshooting-info-parts-list-changes-schematics.html)
Early_S_Man 06-15-2005 01:05 PM
Well, guys and gals ... while working on a 1972 production model CDI unit for a Pelican friend ... it seems that a bit of time needs to be taken to document some of the engineering change history of these CDIs. [edit] Confirmed by email that 'A' is beginning, and 'E' is the end of the windings!
This thread is intended primarily for documentation purposes, not dialogue, maybe a prelude to a Pelican Tech Article ... this thread will be the 74th that will show up in seaches for 'CDI' in the title ... previously I posted one for the later 6-pin Bosch CDI used in SCs and Turbos, so this thread will deal strictly with the 3-pin versions over the years 1969 thru 1977.
Someone out there who knows technical German [as opposed to conversational dielects] ... can help me and others with a small detail regarding the transformer ... there are three windings W1 - primary, W2 - secondary, and W3 - feedback ... the parts layout diagram labels the ends of each winding 'A' or 'E' such as W1A or W3E ... so what are the German words, and which is beginning, and which is ending of the windings??? I have added these labels to the schematics and parts diagrams/pics, since they are important details to be observed during disassembly and repair.
Bosch testing and service parts documents which I previously posted in the following thread were not dated, but are from slightly different times, as the schematic and parts layouts for the circuit boards and schematic are somewhat different. The test document seems to be from late 1973 [though not completely consistent with my early 1973 version schematic and parts list] and the parts document slightly later, as one 470 Ohm resistor, R4 -- present in 1973 and earlier versions was eliminated from the parts list and later parts layout and schematic. There are some slight discrepancies and mislabeling that show up inside/between the two Bosch documents, but they aren't significant enough to be called mistakes ... just typical typos in references that happen when multiple versions and revisions of documents exist during writing of technical documents.
http://forums.pelicanparts.com/showthread.php?s=&threadid=160537&highlight=bosch+ permatune
I will post pics and diagrams as they become available and edit/remove any that become redundant as revisions are made and typos/mistakes are discovered.
Any one with pics or other data can email me through Pelican ... if you want to add data to the compendium!
http://forums.pelicanparts.com/uploa...1138414059.jpg
http://forums.pelicanparts.com/uploa...1138414270.jpg
Here are the first of the Bosch documents:
http://forums.pelicanparts.com/uploa...1084538148.jpg
http://forums.pelicanparts.com/uploa...1084538217.jpg
http://forums.pelicanparts.com/uploa...1084538299.jpg
http://forums.pelicanparts.com/uploa...1084538375.jpg
http://forums.pelicanparts.com/uploa...1084538464.jpg
http://forums.pelicanparts.com/uploa...1084538571.jpg
http://forums.pelicanparts.com/uploa...1084538634.jpg
http://forums.pelicanparts.com/uploa...1082044649.jpg
Early_S_Man 06-15-2005 03:34 PM
http://forums.pelicanparts.com/uploa...1084551922.jpg
http://forums.pelicanparts.com/uploa...1084552092.jpg
http://forums.pelicanparts.com/uploa...1084552237.jpg
http://forums.pelicanparts.com/uploa...1084552517.jpg
http://forums.pelicanparts.com/uploa...1084552636.jpg
http://forums.pelicanparts.com/uploa...1084552788.jpg
This is the board layout/picture for the 1972 CDI unit ... it corresponds to the fig. 17 layout in the test document:
http://forums.pelicanparts.com/uploa...1118874175.jpg
Here is the early schematic for 1969 - 1972 CDI units ... Please note that the test point labels in the test document do NOT correctly correspond to all of the labels in this version of the schematic [TP #1 and TP#2 are OK for scope tests, but to short main capacitor -- TP#4 & TP#4a are used ] ... based on an estimated 1974/75 revision:
http://forums.pelicanparts.com/uploa...1138498607.jpg
Here is an annotated picture/layout for an early 1972 CDI unit corresponding to fig. 16 in the test document.
http://forums.pelicanparts.com/uploa...1138088834.jpg
Here is the revised parts list showing R4 and 33 Ohm 5 Watt version of R3:
http://forums.pelicanparts.com/uploa...1118874874.jpg
ischmitz 06-15-2005 09:23 PM
I have come across at least two major revisions (PCB board layouts) of the 3-pin boxes. Also sometimes ZD3 is one 12Volt and one 10 Volt diode in series covered in isolating tubing. Your image seems to be the earlier version, later version had components aligned only in either 0 degree orientation or 90 degree orientation as shown below.
http://forums.pelicanparts.com/uploa...1118895786.jpg
Cheers,
Ingo
mjshira 06-15-2005 09:36 PM
the oracle has spoken
Lorenfb 06-16-2005 07:41 AM
A number of errors exist in the schematics!
Early_S_Man 06-18-2005 02:00 AM
Ingo,
There are at least eight different board revisions up to 1973/74, and some more revisions for '75 thru '77! Probably 16 or more versions, total, as the one Bosch schematic I have is labeled 'Bild 15' ... and it isn't the last version for the '77 model cars!
Your pic is identical to my '227' date-coded unit built early in 1973 model production, and the last/best layout documented in the Bosch test document!
Here is the 1973 version schematic:
http://forums.pelicanparts.com/uploa...1138499120.jpg
This is the same board layout in my '73 unit date-coded 227 ... 27th week of 1972, which has both R4 and a 120 Ohm R3 pullup resistor . Note it has two D4 diodes, yet also still has R4.
http://forums.pelicanparts.com/uploa...1084551219.jpg
Another variation in component values for the '72 model is C11 ... 1.5 mFd instead of 1.0 mFd!
http://forums.pelicanparts.com/uploa...1119085181.jpg
Early_S_Man 01-20-2006 06:16 PM
Here is info on the last 3-pin CDI ... 0.227.200.008 from 1976 - 77:
http://forums.pelicanparts.com/uploa...1137805244.jpg
http://forums.pelicanparts.com/uploa...1137805438.jpg
http://forums.pelicanparts.com/uploa...1137869493.jpg
http://forums.pelicanparts.com/uploa...1137870868.jpg
ischmitz 01-20-2006 09:42 PM
Thanks Warren. Can you comment on your suggestions of replacement SCR types and how you came up with them? I tried to PM you but never received a response.
Cheers,
Ingo
Early_S_Man 01-24-2006 02:00 PM
Ingo,
I have had over 40 years of successful experience with International Rectifier SCRs, so it was no surprise finding an appropriate datasheet for an SCR to replace the CDI part. Trial installation of the IR parts I already had on hand, 16RIA80, worked well with no failures. Later, some 25RIA80s were tried, and they worked well, too. Recent pricing and availability checks at Newark found the qty 1 price for 50RIA80 @ $14.30, compared to $17.75 for the 25RIA80, so that seems like a good value for what should be a bulletproof solution for the CDI.
A few years ago I found some old stock Siemens CS23-10 and -12 SCRs from the '90s, and both worked quite well in the CDI units ... but those were a one-time deal, and I haven't found any equivalent Infineon parts available at all! A recent search found IXYS parts by the same number, and readily available from Digikey, so they seem like viable alternatives to the IR parts.
Finding the cheapest SCR around that will fit is not what I advocate ... considering the hassle of unsoldering the 17 wires on the board of the 3-pin CDI units.
One line of replacement parts I do not recomment is NTE ... they aren't cheap, but they also aren't JEDEC-registered, either, so I say leave them to the CB radio and audio repair techs!
impmad2000 08-18-2006 12:04 PM
ZD3 trouble
Hi Guys,
I have been fixing quite a few of these CDi boxes here in the UK for a various early cars and with no trouble. Now I have a unit that seems to keep blowing the ZD3 ! I have used a 1N5358B to replace the now obsolete ZM22. Now as far as I can see the 1N5358B is higher rated device, and as such should be capable of taking Over volt spikes far better than the original. But this is the 2nd device I fitted that has failed in this unit ! Can anyone give me any clues ? This is a protective device, designed to take out high voltage spikes and to prevent excessive Vce voltages taking down the transistors right ? Shouldn't it be protected by a series R, like R12 in the later units ? I haven't seen this R12 in any unit yet , do you know the value/power used ? What device are you guys using for ZD3 ?
Thanks in advance, this thread has been invaluable to me in fixing the units that I have fixed. Thank you for this mine of information
Tim Bennett
impmad2000 09-05-2006 11:27 AM
further to the above problem, I have two other units with dead thyristrors. I took the bullet proof approach, 50RIA100 devices. In both cases, one a 6 pin, the other a 3 pin, both units will drop into an self triggered mode (Permanently conducting) there, one can be triggered by straight into this mode at cold, the other more susceptible at high temps..... Any thoughts ?
I haven't been able to find a data sheet on the old AEG thyristor yet... this may help. Thinking some kind of Dv/Dt problem but the rise rates seem way too slow ! Argh... I'm more used to '1's and '0's
Cheers
Tim
ischmitz 09-05-2006 08:57 PM
You need to select a device with low tQ time. Ideally, it needs be be on the order of less than 30 usec. Typical tQ times for all the current off-the-shelf devices are on the order of 90 - 120 usec. This causes your issues.
Ingo
impmad2000 09-11-2006 08:16 AM
Hmm, I see. Having scoped the relevant points in the circuit, and searched on the net for suitable thyristors, I see the problem. Do you think I should experiment with the snubber circuit to see if I can extend the -ve voltage swing. What devices are being fitted as replacements ? Are you finding old stock devices ?
Thanks for your input
Tim
ischmitz 09-11-2006 08:54 AM
I once found a perfect fit albeit in an isolated TO220 housing. It worked like a charm. Unfortunagely, I don't remember the JEDEC number on top of my head. Other than that it seems to become more and more difficult to find fast enough devices. I don't know why but it has to do with the semicinductor process......
dweymer 10-03-2006 03:25 PM
I am just adding this link to some more test info:
http://forums.pelicanparts.com/porsche-911-technical-forum/307317-cranky-cranky-no-sparky.html
jmchrist 02-08-2007 03:53 PM
Bosch CDI unit 0.227.200.008
I am new in this forum where I found very valuable information on CDI schematics that allowed me to repair a few units in France (I am a retired electronics engineer).
I am grateful in particular to Early_S_Man for his set of various versions of Bosch CDIs.
So I am willing to bring my two-pence contribution :
The schematics given above on CDI version 0.227.200.008 is incorrect.
When I measure the value of R12 resistor I found 15 ohms.
Since the consumption of a unit is between 1 A and 2.6 A, it is obvious that this resistor is not at the indicated place.
I have made the corrections I found on the attached picture, highlighted in yellow.
Please notice the added diode (D8) that seems to exist only on this particular model.
I hope this will be of some help.
http://forums.pelicanparts.com/uploa...1170978761.jpg
Kevin Taylor 02-09-2007 09:22 AM
Great Post.
Thanks.
K.T.
1973 911 E 2.4 MFI
1983 911 SC
1978 911 SC
1965 Devin "D" - 1967 912 Power Plant
jmchrist 02-09-2007 01:11 PM
CDI unit ...008 or ...001 ?
Hello
Please find attached the picture of the CDI unit corresponding to the modified schematics I posted yesterday. The components concerned are indicated.
In particular the diode D8 is situated in the upper left corner, above R12.
BTW I have to confess that I did not pay attention to the box containing this printed circuit. In fact it is not labelled 0.227.200.008, but...001 !
One more model of 0.227.200.001 !http://forums.pelicanparts.com/uploa...1171055448.jpg
Jays72T 02-09-2007 02:25 PM
I feel dumb as a stump but thanks for this.
Early_S_Man 06-19-2007 02:37 PM
Thanks go out to jmchrist for providing corrections and pics of the modified '001' CDI ... most likely done at a Bosch service center or the factory when the unit was sent back for repair. Please note that C13 was changed to a 0.63 uF cap!
Here are a revised schematic of the mod in two versions, one for color inkjet or laser printing, and the B/W version for monochrome lasers:
http://forums.pelicanparts.com/uploa...1182288538.jpg
http://forums.pelicanparts.com/uploa...1182288585.jpg
You can use Irfanview to rotate and save the pic, or print it.
gulf blue rsr 09-05-2007 02:56 AM
S man you are a fantastic asset.
Found this thread today and have not yet read the vast detail, so this may be a silly question. but here goes.
I have several six pin units which are faulty.
Have you any suggestions for a set up for bench testing these six pin units out of the car when I have "repaired them".
What precautions do I need to take if I run the six pin unit on a bench DC power supply in order to test it?
I can think of several ways of doing it but can you suggest how I can best supply the input pulse to point 7 to test the unit as in the car, can I leave the output open do I need to fit a coil to the output end or can I load the unit with a ballast resistor?.
ischmitz 09-05-2007 07:38 AM
Make sure it has enough current capacity to drive the CD unit. It should be rated at 5 Amps or better. As a precaution a power supply with current limiter function is a plus when troubleshooting a faulty unit.
You can use a simple NE555 as pulse generator. The 6-pin requires a negative input pulse to trigger. Circuits can be found online. If you have access to a function generator with variable frequency output it is a plus since some units fail at different RPM.
Can I leave the output open do I need to fit a coil to the output end or can I load the unit with a ballast resistor?
If you leave the output open you will not test the final stage of the CD unit. DON'T USE A BALLAST RESISTOR. IT WILL DESTROY THE SRC. The CDI is designed to discharge the capacitor into an inductive load (the coil) You can hook up a used coil and a used spark plug on the bench. That way you can properly bench-test the unit. Be careful when working on the open box since you can seriously shock yourself on some of the life components. There are around 400V present at the SCR and capacitor.
Hope that helps,
Ingo
Lorenfb 09-05-2007 08:16 AM
"Have you any suggestions for a set up for bench testing these six pin units out of the car when I have "repaired them"."
Actually, the testing is really the 1st step prior to repairing.
If one lacks the testing knowledge, the "repairing" becomes questionable.
jmchrist 09-05-2007 09:26 AM
Just as an example, please find hereafter a picture of the test bench I am occasionally assembling (at home !) to repair 3 or 6 pin units.
Attached is also a picture of the modified plug used for the test. The modification is done for increasing the gap to about 6 mm (0.25 inch) in order to reach at the atmospheric pressure about the same disruptive voltage as in the cylinders.
I am using a pulse generator for simulating by RC derivation the output of the pickup coil for 6 pin units, and a simple square wave generator for testing 3 pin units.
About the power supply, if a battery is not used it is to be noted that, due to the highly inductive equivalent load of the internal flywheel converter, some energy is sent back into the power supply during a part of the 3 kHz cycle (I have measured up to 4 A peak !), so that it is useful to connect a large electrolytic capacitor in parallel at the output.
I use a 470 µF cap. for that purpose.http://forums.pelicanparts.com/uploa...1189009281.jpg http://forums.pelicanparts.com/uploa...1189009476.jpg
Lorenfb 09-05-2007 11:09 AM
"I am using a pulse generator for simulating by RC derivation the output of the pickup coil for 6 pin units, and a simple square wave generator for testing 3 pin units."
Actually, a simple sine input is all that's needed for the 6 pin with an added transistor switch
for the 3 pin.
Also, to avoid CDI damage or heart failure, the spark plug needs to contact the
CDI case, i.e. the coil ground terminal.
"some energy is sent back into the power supply during a part of the 3 kHz cycle (I have measured up to 4 A peak !), so that it is useful to connect a large electrolytic capacitor in parallel at the output.
I use a 470 µF cap. for that purpose."
It all depends on the output impedence of the power supply, i.e. its characterics.
jmchrist 09-05-2007 12:28 PM
This is correct for the operation of the unit, but for observing the triggering of the SCR the slope of a sinusoïdal signal is not fast enough for not to be perturbed by the interference with the 3 kHZ frequency of the converter. This interference is the source of an instability perturbing the observation with an oscilloscope of the triggering signals.
This instability disappears with a sharper input signal.
Oh ! sure ! Did not you see the brown wire on my picture ? ;-)
Sorry, I disagree. This is not a question of output impedance. The ability of a power supply to accept some current back is rarely (may be never) specified and do not depend on the output impedance, which is normally specified only for current flowing in the forward direction, not in the reverse direction.
Lorenfb 09-05-2007 08:08 PM
"but for observing the triggering of the SCR the slope of a sinusoïdal signal is not fast enough for not to be perturbed by the interference with the 3 kHZ frequency of the converter. "
Do what????????
Check the signal from the distributor pickup, it's basically a sine wave with distortion,
i.e. harmonics. And what's the purpose of the Schmitt Trigger, i.e slow rising and falling
slopes while cranking. Use a higher freq sine wave.
The output capacitance of a power supply is a factor of its output impedence, i.e. the dynamic
or A.C. properties. Some junk power supplies don't have ANY output capacitors, and thus have
poor dynamic response to LOAD transients.
ischmitz 09-05-2007 11:25 PM
....time to break out the popcorn :D
gulf blue rsr 09-06-2007 02:49 AM
Wow I started something here.
Lets not get to het up it's only a bit of electronic kit.
To put the record straight I am a domestic TV audio engineer with a fully fitted workshop for LCD PLasma DVD and audio products, so I have the kit and well know both my limiuts and the limits of power supplies etc, I have enough info from this and other threads to sort the rig I need and that is what I asked for (thanks s man jmchrist and impmad2000 here and else where). gulf blue rsr is my son who I am helping out with the problems with cdi units.
What strikes me so far is that for the asking there is a load of information on these units and with some luck and a lot of reading I should be able to sort them but I cannot see for the life of me why these units cost so much to repair else where.
Thanks to all for your input all I need now is a supply of parts and again with the help of these threads I think will be able to souce them also.
Lorenfb 09-06-2007 08:18 AM
When all else fails, order a rebuilt unit from Pelican Parts!
gulf blue rsr 09-07-2007 12:42 AM
Nice one folks, burnt the midnight oil last night and managed to get two of the units up and running, couple of zenners and a dry joint, not easy to find but we got there.
on wards and up wards as they say.;)
Early_S_Man 09-07-2007 10:52 AM
Congrats to Gulf Blue RSR, Sr. on the repair!
<b>Bad connections, to include bad solder joints, both on the printed circuit board and to the 'flea'clips where the 15 or 17 wires attach, and Faston connectors of the loose and corroded variety ... are the most common failure mode for the Bosch CDI units!</b>
I had originally intended to confine discussions of the 6-pin units to the following thread, but it doesn't really matter to me ... dial-up users may have to suffer, though!
http://forums.pelicanparts.com/showthread.php?t=203100&highlight=cdi+documentatio n
I normally use a Tektronix RG-501 Ramp Generator in a TM515 mainframe to trigger 6-pin units. The manual can be downloaded here:
http://www.bitsavers.org/pdf/tektronix/tm500/070-1352-00_RG501_Jul72.pdf
Almost any function generator, time mark generator, or pulse generator could be used to trigger the 6-pin Bosch or Permatune CDI units, but I already had the ramp generator ...
Here is a thread about a DIY CDI project that may be of interest to some out there who like the idea of a newly-constructed spare CDI unit ...
http://forums.pelicanparts.com/porsche-911-technical-forum/353053-diy-cdi-kit-1997-silicon-chip-magazine-article-oz.html?highlight=diy+cdi
Here are a couple of new revised schematics to include all three of the lumped suppression resistors in the coil output circuit:
http://forums.pelicanparts.com/uploa...1189151981.jpg
http://forums.pelicanparts.com/uploa...1189187000.jpg
HKZ Bob 10-28-2007 09:08 AM
What is the load over the (R12) 15R ?
100 mA ?
bob
Early_S_Man 10-28-2007 01:04 PM
Bob,
With a nominal 14 Volt input from the alternator ... it is easily less than ~ 70 mA with T2 fully conducting.
HKZ Bob 11-02-2007 12:12 PM
Warren I have a 3pin Box which has an R4 but not a R12 & Diode D8.
What year was that?
Bob
Early_S_Man 11-02-2007 06:05 PM
Bob,
1973 was the only year I know of that still had R4.
Can you post the datasheets of the AEG SCRs here?
Lorenfb 11-02-2007 07:30 PM
The R4 resistor was used on all the late 3 pin CDIs until the 6 pin CDI
to reduce the susceptibility to input (#15) noise level, e.g. alternator,
fans, RF ignition, & etc.
HKZ Bob 11-03-2007 12:38 AM
Hello so this is a 73 CDI, the R4 is a 270R resistor.
It is placed between W1A & R5.
http://forums.pelicanparts.com/uploa...1194074727.jpg
Regards
Bob
HKZ Bob 11-03-2007 12:26 PM
Warren
W stands for "Wicklung" which english word is winding
E stand for "Ende which is end
A stands for "Anfang" which is beginning....
Bob
HKZ Bob 11-05-2007 05:00 AM
Dear all,
it took me a long investigation for these datasheet.
I like this forum and that why I post these TxxN x00 COB M datasheets.
The rise time is 2 micro seconds
The closing time is 50 micro seconds. So the RIAs series does not meet these values.
http://forums.pelicanparts.com/uploa...1194267336.jpg
http://forums.pelicanparts.com/uploa...1194267361.jpg
Regards Bob
