Air Medal or two
Floor tile (where?)
Is there a deal on floor tile anywhere for my shop?? and while on the subject a good layout??
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
Alter Ego Racing
Check here:
http://www.costco.com/Browse/Productgroup.aspx?prodid=11038308&ec=BC-EC877-CatHome&pos=4
International GT Champion; Porsche GT3 Cup Trophy Champion; Klub Sport Challenge Champion; Rolex Vintage Endurance Series Champion; PCA Club Racing Champion; National Vintage Racing Champion |
Air Medal or two
thanks!!
I thinks I want to mix some red in there...so Ill keep looking too
You can buy comercial viynl tile in any color you want for .60 a foot from a home depot type store it's bullet proof ! I just did my garage floor cleans up great and only cost me $400.00 for tile and glue. Best part is if one gets damaged a heat gun loosens them right up and you can replace the bad tile.
1986 blk 930 2000 expedition 2000 bmw 3 series convertable 1996 Silverton 312 sedan bridge |
Automotive Monomaniac
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) |
Did you look into an epoxy coating? That is what I am going to do in my shop.
Mike
'77 911 3.0 '94 Mustang GT '77 911 (soon be a real live racecar!) |
Air Medal or two
I am probly just weird.....want the "look" of the 60s or something,so floor tile is my bag for now.
Thanks for the replys Ill check it all out.
Ya, that black and white checkerboard look is pretty cool.
Mike
I did mine in 1'x1' black and white my friend did his garage in 4'x4' ( 4 tiles together ) looks cool.
Mine are 2x2 - looks great also.
I went with white (kinda) and grey VCT tiles, in an attempt to keep it as bright as possible under the car, but retain the checkered look. It WILL dent, and burn and stain..oh well
, but it easy to swap out. There is no better bang for the buck! It is VERY reasonable, and easy to apply with little prep required. I've done the painting, and the epoxy coatings, but they burn from weld splatter and scratch as well, and if the concrete is old, they plain just won't stick without big time prep. And even then.... The VCT is great, but if you use the car in wet or snowy climates, throw down a bit ofself stick non slip stuff to avoid landing in the family room!
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
Oh...one more thing...using the 12" tiles makes a great scale on the floor to use for all sorts of measuring projects..
My garage with white tile.
1972 911T 1991 Mazda RX-7 Turbo II Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life! |
The epoxy's I have used have never burned from welding splatter. I have used a professional installer for them tho. Not the do it yourself kind.
Mike
