bulb replacment
I have a couple of burned out bulbs behind my heating and air control levers on the dash. Is there a simple way of getting at these bulbs?
bk
Old 10-19-2004, 03:31 AM
3.2 CAB's Avatar
What are they on?
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 10-19-2004, 05:58 AM
1983 911 CAB
Old 10-19-2004, 02:28 PM
450knotOffice's Avatar
Question
Is there lighting behind the heating and air control levers? I've had my car for a month and there is no backlighting behind my panel. I just assumed that it wasn't installed - you know, old dashboard style and all. Hmmm.
Old 10-19-2004, 02:53 PM
84CAB's Avatar
Yes there are bulbs behind there... they are hard to reach but if you lay in the floorboard and shine a flashlight you should be able to see them...helps if you are small and flexable!!
ELVIS 84 CAB -SOLD
Old 10-19-2004, 03:59 PM
3.2 CAB's Avatar
You should be able to just reach under and pull them out, if I remember right these are all 2 pole plastic lamp sockets. I think it should have one in each upper corner of the switch plate.
Newest additions-
others...
Old 10-20-2004, 02:03 AM
I had to pull the radio out and then after some bloody knuckles I got them
bk
Old 10-20-2004, 03:05 AM
bigchillcar's Avatar
i'd rather be able to replace by this method as well, but can you access the bulbs with the old factory air ducting in the way? anyone know where to find the correct bulbs?
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 06-17-2005, 11:54 AM
lol, pulling out the bulb holders is the easy part. Get the little f**kers back in requires Zen like skills, flexible fingers and the patience of a saint. A great place for the super white LED's -stick em in and never have to go back again.
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 06-17-2005, 12:01 PM
ron, did your car have the a/c ducting in place to have to work around? i'm dreading trying to get my 6'2", 220 frame back in that upside down, nearly kill my nearly 40 year old back position. where's a flexible zen master when you need one??
ryan
Old 06-17-2005, 12:05 PM
