Gon fix it with me hammer
ditching heater what about MFI
anyone has been stripping the heater stuff out of an 72 MFI car?
first i want to get ridd of my heater stuff since i only drive during summer. first the hoses , block off plates, flapper box and blower motor... eventually remove the heat exchangers and use simple exhaust headers. my question is : i've heard that the MFI system is somehow connected to the heat exchangers, and it somehow uses this to regulate cold/hot running...but i haven't got a clue how this works, and how it will affect my engines operation when i perform the above work will my engine work different if i just disconnect the heater hoses? do i need to do something on the mfi? i'm not modding for racing or anything, i'm just looking to simplify the car to just what i need it to do... is there someone around who knows the low down on this? thx, Stijn
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
There WAS someone around. . . Roland Kunz. . .
In a very old thread, Roland described, in his ininmitable way, the various ways the factory got around no heat exchangers. Quote:
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) Last edited by 304065; 11-04-2003 at 11:54 AM.. |
Friend of Warren
But keep in mind that the early heat exchangers have a header type set up in them, not equal length, but I see no HP increase from going to headers on your car.
Kurt V No more Porsches, but a revolving number of motorcycles. |
i'm not thinking hp increase, more like
less problems with oil drips stinking up when burning on the HE's easier acces , less cluttered engine bay mine are currently stainless steel...
There should be a hose that runs from the left side HE up to your MFI pump. That hose pulls air across a thermostat leaning the mixture. I'd pull all the heater stuff and leave the MFI part of the shroud on the HE's
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
wouldn't there be a way to manually override the mixture
say if i use the handle that normally controls the flapperbox?
there's actually 2 sets of hoses from the HE. there's the large one to your intake that almost nobody has or uses anymore since it's an emmissions device and there's the MFI pump hose which is essential to operation.
Which one are you refering to?
i want to get ridd of all that's not wanted , so it seems i need to stick to the MFI one... or find a workaround...
There's a work around with a light bulb or a cover plate. Check the archives and there should be some good info.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Friend of Warren
Do a search on this board. I know of at least one or two guys that have come up with manual ways of adjusting the MFI thermostat.
Friend of Warren
![]() condradictions... that's the only drawback on this BBS ![]() guess i'll have to find out the hard way and see what happens
Double Trouble
The discs EXPAND to change the mix. The lightbulb thing is novel to say the least. I am with the prior. If the headers you have are SS and equal length there is very little to gain by eliminating the heater. I mean you can lose the control flappers, that would work. But as far as stopping the drips..it will still drip on the header pipe, with or without the exchanger shrouding. The manual lever in the cockpit only operates the throttle linkage and has nothing to do with mixture. The thermostat needs warm air blowing over the discs to expand them. So you need AIR FLOW over them, in my mind making the exchanger shrouding necessary. No heater shroud no way to get air pressure to the back of the exchanger where the warm air pipe connects. good luck. Keep us posted as to what you come up with.
I used to be addicted to the hokey pokey..........but I turned myself around.. 75 914 1.8 2010 Cayenne base |
beeing the newbie at techie stuff, i'de say it might take a while
befor i actually start ripping out the guts of my car.. i'll start by removing the right side of the car's heating...less things i can screw up ![]() btw noticed you got a 0111 too , greetings dude !
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 Last edited by svandamme; 11-04-2003 at 12:57 PM.. |
Monkey with a mouse
Stijn:
My former 911 had no warm-up circuit. It did have some fuel "foggers" that were piped into the trumpets that were activated by a switch in the cabin. On cold starts, depressing the fogger switch for about 2 seconds before ignition would allow the engine to start dependably. It probably also served serendipitously as a theft prevention device as it was difficult if not impossible to start the motor if one did not know how to use the switch! The former owner and builder of the motor had a dial in the cabin where he could richen or lean out the mix - I told him that I (a novice!) did not want that level of control because I would probably frack things up. ![]() Here's a pick where you can see the "hoseless" modified RS MFI pump: ![]() It can be done! BR, Kurt |
sweet looking engine Kurt !
looks better than the stock huge air intake box i have would you know what exactly need to be modified to end up with a foggerswitch setup like you have?
Monkey with a mouse
Thanks!
Well, I don't know how "exactly" it was done, but I think I can explain in a general way. There were six individual, very thin, fuel lines that went into the outside of the intake trumpets - I think they were about half-way from the top and bottom - that sprayed the fuel. The very simple electric button switch was installed under the dash and it somehow caused fuel to be delivered into the above mentioned thin fuel line; how this part was accomplished is the critical piece of the puzzle I don't know. I am not sure if there was an "extra" pump or if somehow one of the existing pumps was used to spray the fuel. I think someone here much smarter the I can probably backwards engineer such a system. Good luck! BR, Kurt |
Well if you do, and the ss exchangers are in good shape, i'll buy them
72 911 Although it is done at the moment, it will never be finished. |
