-   -   67s w/points self tapped into distributor - help (http://forums.pelicanparts.com/porsche-911-technical-forum/227097-67s-w-points-self-tapped-into-distributor-help.html)
1967911s 06-19-2005 02:39 AM
just got 1968 2.0s back from mechanic and he has used a self tapping screw to secure the points to the distributor, whilst this works, I can't imagine is a good long term solution.
what are people's thoughts, i'm assuming that i can buy replacement parts to fix this, and may need a new distributor A-602-021-50 - $$$, no longer available...
is the AMD option a solution?
many thanks Rich
911mot 06-19-2005 03:39 AM
I don't think it's a major problem. Unless you are going for concours and don't want a judge to pop the cap....
Infact I've had to resort to a self tapper myself a few times over the years. Sometimes because the thread in the base of the distributor get's stripped, and sometimes because of a screw dropped into nowhere land. That said 911's are one of the easiest cars in the world to change points on, so dropping and losing the screw is possible but not likely
1967911s 06-19-2005 03:44 PM
not worried about concours, just keen for the distributor not to self destruct on the m3!! thanks for the post..
buster73 06-19-2005 07:14 PM
They say - never buy a car from a mechanic ! However this should not be a big problem. If the screw comes loose, you can always dismantle the distributor, weld the hole, drill and tap a new thread.
