Somatic Negative Optimist
Gunter's Avatar
Question Oil return tubes, two-piece Alu style question
These are in really good condition: Two-piece Alu, no circlip, with 3 small O-rings in the center and a large red O-ring at each end.
Where do I get the small O-rings? Are they just standard size?
Are these Alu-two-piece OEM? Aftermarket?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 06-29-2005, 10:22 PM
shrouded's Avatar
Send a message via ICQ to shrouded Send a message via AIM to shrouded
If these are the standard two-piece oil return tubes, our host sells both the tubes here.
1982 911SC - Metallic Rosewood
Old 06-30-2005, 06:45 AM
Unregistered
sammyg2's Avatar
I'd call pelican first. They can prolly supply them.
If you can't find the o-rings, give me the ID and cross section dimentions and I can look up the dash number in one of my books. Then it is just a matter of finding the viton o-ring which is very easy too. I have a couple places where you can order them and have them delivered.
Old 06-30-2005, 08:03 AM
Gunter's Avatar
Thanks shrouded, I know about that link; PP shows the two-piece STEEL-version with the circlip. What I have is two-piece ALU version without circlip but with two thin O-rings inside and two larger ones at each end.
Thanks for the offer, sammyg2, I'll do some measuring.
If these ALU tubes wouldn't be in perfect condition, I would just get the steel version. But......................
Old 06-30-2005, 07:19 PM
Jeff Alton's Avatar
If this is for the 3.2ss, just put new 1 piece factory ones in, they are cheap and much more reliable.
Jeff
www.turn3autosport.com
Old 06-30-2005, 07:37 PM
You peel off the orings, Do a google search for industrial rubber in your town. I found 2 in San Carlos, CA. One of them just gave me a handful for free.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 06-30-2005, 07:48 PM
Gunter's Avatar
Thanks, yelcab.
Hi Jeff, I am far from putting anything in; I am just getting stuff together. So, when you rebuild the motor on the stand, you go with a one piece OEM? O.K. (But these ALU tubes are really beautiful!)
I am still dismantling and still don't know what P/C's are in there. My gut-feeling is that the are KS (I can't be lucky twice!) Because it is done on the back of my 1/2 ton, the engine sits on the heaterboxes. Therefore, I cannot take the heads off since I have to turn the engine over to remove the headers/heaterboxes.
I am taking as much off as I can before I turn it over.
Man, there is sooooooooo much cleaning to do! Is there a short-cut to getting the grime/oil off the parts?
Old 06-30-2005, 07:56 PM
Early_S_Man's Avatar
Porsche Crest
If those aluminum oil-return tubes are rather thick, and have a large, external spring to maintain pressure on the sealing rings ... they are an aftermarket set from IXXI Enterprises in Dallas TX. The O-rings should be standard sizes available at any industrial bearing & seal supply store.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 07-03-2005, 07:49 AM
Gunter's Avatar
Thanks Warren: They are as thick as the two-piece steel ones and pretty solid but, they don't have an external spring. When installed the two thin O-rings inside the tubes seal between the two pieces and the ends have the larger O-ring that goes into the case/camtower. To keep the two pieces extended, there is a third O-ring right where the circlip sits on the steel ones.
Old 07-04-2005, 08:12 AM
