Re arcing distributor for modern gas?
Is this true? I have a 1970 911 and I had someone tell me that in order for it to run properly on today's gas the distributor needed to be re arced. It's for the most part completely stock.
thanks allan |
Navin Johnson
They may be talking about having your distributor re-curved
but you should not have a problem running an early car as long as you use the highest octane gas available
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
thats what I thought.
thanks |
and yes i meant re-curved. oops!
Run good fresh gas in it. You will be ok.
David Duffield |
