Cup 1 rims from a 1994 964 will fit a 1987 911?
Hi, do you folks know if original Cup 1 rims from a 1994 964 will fit on a 1987 911 Coupe without using spacers?
I'm looking to buy a set and the seller is telling me they will fit fine on an '87...I'm just looking for some verification.
2014 Porsche Cayman S 2001 BMW 525i Touring 1996 Porsche 911 (Gone to Germany) '86 911 Carrera (Gone to Aruba) |
Is it the ones on craigslist? If so, I believe those are replicas that have the correct offset, basically a built-in spacer.
ßrandon |
I emailed some guy on craigslist about some Turbo Twist style rims, but never got a reply back.
PRO Motorsports
If they are Factory, then you need 1" spacers in front, and 1" or 1.5" in back, depending on how much negative camber you're running.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
Hmm .. to my knowledge anything past 89 had the "late" offset, et40-ish and above.
Edit: What Tyson said
ßrandon Last edited by 87coupe; 06-20-2005 at 09:40 PM.. |
I'm a Country Member
The offset on the Cup rims (17x7/9) both f and r is 55.
Stuart War crimes will be prosecuted. War criminals will be punished. And it will be no defense to say, 'I was just following orders.' George W. Bush |
Cup design 92 (Cup1) The above are for fitment on a 964 on a 911 they all need spacers, depending on the app. 7JX17 55 needs ~31mm spacer in front, 9JX17 55 needs ~40mm spacer in back, different width spacers can be used to pull the wheel in or out a bit
