Kevin Stewart's Avatar
3.6 help engine vacum hose
what hose did you guys with sc cars hook up here, can i just put a small chrome breather on it, thanks, Kevin
Old 06-20-2005, 07:55 PM
blue82coupe's Avatar
Kevin, Fairly certain the bottom connector goes to power brake vacumn booster.Dan
I have plenty of lead for my pencil... just not enough paper to write on..
82SC with 95 993 engine
2004 Ford Powerstroke
Old 06-20-2005, 08:09 PM
this picture is of a 993 motor my motor is a 964, I cant see how its for brakes when its sucking, Kevin
Old 06-20-2005, 08:16 PM
Thought it was a
varioram engine. One of the connectors is the evaporative system ,the other goes to the power brake booster... and yes the booster uses vacumn to operate.The fitting to the evaporative system should have an electrical connector also. Dan
Old 06-20-2005, 08:31 PM
I still dont understand how it can be for brakes if its pulling air in the motor, Kevin
Old 06-20-2005, 08:34 PM
What year car is the engine going in? Dan
Old 06-20-2005, 08:46 PM
the engine is a 93 and its in a 82
Old 06-20-2005, 08:47 PM
ok I found a picture bill posted, Kevin
Old 06-20-2005, 08:57 PM
wot wot is offline
wot's Avatar
Hi
The bottom fitting is for the vacuum for the brake booster, and should be connected,
No air is being sucked it to the engine, only vacuum for the brake booster.
The top fitting is for the tank venting and should be connected to the evap system or blocked off.
Erik
82 SC 3,6 73 RS Look
Old 06-21-2005, 12:01 AM
the bottom line is sucking air, trust me i put my finger on it, Kevin
Old 06-21-2005, 12:48 AM
wot wot is offline
wot's Avatar
Hi
yes it is sucking air, but the brake booster is a closed unit, when it is connected you get noting but vacuum
Erik
Old 06-21-2005, 12:56 AM
Bill Verburg's Avatar
Bill Verburg
Old 06-21-2005, 03:11 AM
One this hose is off the car idles better, when on it smells rich, Kevin
Old 06-21-2005, 09:27 AM
