Shock replacement please help
wondering if bilstiens from an 84 will bolt right into a 77s with bilstiens? thanks in advance Marty
Old 06-22-2005, 09:52 AM
sorry,also sway bars and torsion bars thanks
Old 06-22-2005, 09:55 AM
randywebb's Avatar
look up both years on the Pelican catalog and see if the p/ns are the same
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 06-22-2005, 11:17 AM
ecm911's Avatar
Martin,
I am oit an expert, but believe that the 84 shocks and torsion bars should fit. Not sure of the sway bars though. It is my understanding that Pre G-50 cars have the same torsion bars.
Hope this helps. Hopefully someone with a 77 will chime in here.
Good Luck.
Earl
78 SC Coupe
93 RSA (Gone)
Old 06-22-2005, 12:57 PM
mark_d_mcguire's Avatar
I had a 77 and replaced inserts without issue. T-bars and front sways are OK too.
Rear sways have a different connector to the trailing arm. I think if you reuse your drop links, you should be OK. I'm not sure on this one, as I replaced with an aftermarket sway bar.
Mark
H Class Race Car Project
Old flames: 1999 C2 Race Car #78; 1983 SC Race Car; #78; 1990 C2; 1978 SC Race Car #78; 1988 Carrera; 1977 911S
Old 06-22-2005, 01:33 PM
