Licensed User
Does anyone make a sheet metal stiffening kit for the rear shock tower area? I know there are 911 rocker stiffening panels and a number of 914 chassis kits out there. Are the rocker stiffening panels any benefit to a coupe or are they only helpful for cabs & targas? I guess none of this stuff would be too difficult to fab if you have access to a sheet metal brake. Is 20gauge sheet stock big enough for the shock tower reinforcements?
Local fella by the name of Geoffrey is prepeping a race 964, he has posted some nice pics here well worth looking at.
Licensed User
The seam stitch welds make a lot of sense. Where are the chassis stiffenning panels a good idea? the rockers, floor to rocker joint, and the boxed sections seem logical to me. Where are the main areas that can be improved on without going to a full cage tied to the suspension points?
Excellent thread! To echo others, I would like to see pics of the reinforced areas. I'm particularly interested in all the mods/reinforcements that can be done just short of a full blown cage.
Bill G. '68 911 Ossi Blue coupe |
Doc, your cars suck!!
just kidding, nice pics. A little more than I had in mind for my barely streetable street car! But now I am thinking full cage......Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Senior Member
Factory Cup cars are seam welded in the "weak spots" and the cages are welded to the A/B pillars.
Aftermarket cab sill plates:
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
I'm in heaven, when I drive my nine eleven... |
Maybe sligtly off topic, but does somebody know who makes that type of roll bar for cabs?
Thom - I can see how the sill plates would help a cab or targa resist buckling (like that pic someone posted of a trage bent into a Z in a crash). But do you think it will help a coupe any? Doesn't seem like it... and doesn't seem that it would help with torsional twist either - only when the front & rear are pushed up and towards each other, bending horizontally at the car's center.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Had an interesting discussion on this subject today with a guy capable of doing it "all".
His comment was , "if I wanted to stiffen the body, first thing I'd do is remove the gutters and weld the 3 biggest sheet metal panels on the car together. The rest of the small stuff just makes specific parts of the uni body stiffer. Full cage being one of the few exceptions. Only reason Porsche didn't always do it (chop & weld the gutter) on the earlier cars was the racing rules (then) wouldn't allow it." He went on to speculate that removing the rain gutter now isn't that common because the majority of "tuners" (guys capable of doing frame reinforcements and full cages) rarely get into doing body work, fiberglass body parts being added as the norm after a full cage. "The cage is needed any way so most stop there...2/3s of the way to being finished." Any of the professionals care to comment on that thought process? Last edited by rdane; 06-25-2005 at 06:51 PM.. |
Stranger on the Internet
Are you speaking of the rain gutters on the roof above the doors?
Patrick E. Keefe 78 SC |
subscribe to see the pics. I'll be doing the sill plates that Thom posted later this summer, also seam welding the the A-pillar base, and anywhere else I can. The plates are tacked together every inch or so by the factory, on some of the spaces in between the plates are separated by a full 1/8 inch.
Tru6 Restoration & Design |
Shaving rain gutters
OK, after looking at this, I understand the rigidity issue with the gutters. Rdane's car looks pretty good there.
I only want to rear coil-overs and I'm looking for a nice mod +, just in case my street coupe has a more exciting future. it's one of those "while you're in there" things. thx
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
AutoBahned
Tyson
Did you end up taking those pics. I know this thread is quite old but I am researching the best way to strengthen my body whilst keeping it looking stock for the racing class I will be competing in. Michael |
Almost Banned Once
This thread should be a sticky...
- Peter |
