Sounds like vapor lock...but skeptical
I have done a lot of searching and reading. I do not think this is another vapor lock thread, but as of yet I am still troubleshooting. Here is the story:
Just got done baselining my baby. Took her out today and took her for a spin. She felt fantastic until we crossed 3k. Then she choked until I left off the gas and dropped her down again. Throughout the run she continued to chole at around 3000 rpms...sometimes a little more sometimes a little less. Later in the afternoon when someone else was driving her she killed and would not start. We let her sit outside for 2 hours and she still did not start. Now the temp was 90-100 degrees today. Presently the car is my garge and we are going to try again when it cools off tonight. Any ideas? I did not change the fuel filter and I will have one tomorrow morning. Outside of that I am clueless. IS it the DME? |
I'm not sure I've ever heard of any 911 getting vapor lock, much less a fuel injected 911. More likely a bad DME relay or clogged fuel system or bad fuel pump. Change out the DME relay first as it is the easiest and relatively cheap to do.
Yeah, I tired to start her last night...no go. SO it is definitely not vapor lock. I plan on replaceing the filter and DME. Hoping that fixes the problem.
After that the fuel pump...after that she goes to the mechanic. |
Bleed the injector rail, see if car starts, check fuel pressure - should be @ 2.5 bar. Leave the fuel pressure guage on, go drive car, see if it dies, check pressure at cut-out. My bet, the guage willl be pegged.
Mine would lock at 6000rpm, turned out to be a bad fuel regulator. Same symptoms. Hydro lock. Spent a lot of bread to find/fix this problem. '87 Carrera. Part doesn't fail often, but when it does... |
The plan right now is to change the DME. If that does not fix it test the fuel pump. If the pump checks out...I am sending her to the wrench.
I leave on SUnday so my Dad will finish teh work. I got to drive her a few miles before I left. |
| All times are GMT -8. The time now is 09:24 PM. |
