-   -   Paint cracking slightly after fender rolled (http://forums.pelicanparts.com/porsche-911-technical-forum/227959-paint-cracking-slightly-after-fender-rolled.html)
drsimonwong 06-24-2005 01:25 AM
After my fenders were rolled some of the paint cracked and debonded leaving small slits that gap ever so slightly.
Advice on what I need to/can do?
Simon
greglepore 06-24-2005 05:41 AM
Not much, now. You can try a little touchup clear just to seal.
Common problem, can sometimes be avoided by heating the paint gently prior to rolling.
}{arlequin 06-24-2005 05:46 AM
"gently" can be taken different ways
my paint cracked after I used a heatgun on the lip
others had success w/ a..... torch!
so the moral is, you have to really heat up the paint... almost to melting point? (I guess)
oh, flake off as much paint as you can (it already happened) then seal it, either w/ Por-15 and touch up, or w/ some clear coat/touch up combo.
Bill Verburg 06-24-2005 05:50 AM
Depends on how bad it is, but I would have the area repainted and reseales on the back side.
This is a reason why i much prefer to cut the lips off. you will only need to reseal the edge.
ruf-porsche 06-24-2005 06:45 AM
Another reason not to roll the fender.
drsimonwong 06-24-2005 07:19 AM
Well I used my touch up paint and "plugged" up the little slits. Not sure that's the best solution but it's the coward's way out for now. Will sleep on everyone's advice.
Simon
RickM 06-24-2005 07:22 AM
In the future one may consider using a pint pen and a clear as a final sealer. TowerPaint.com sells the pen matched to your paint.
NoLift911 06-24-2005 07:47 AM
Bill what tool is used for your preferred method of doing this?
-Jeff
