Paint cracking slightly after fender rolled
After my fenders were rolled some of the paint cracked and debonded leaving small slits that gap ever so slightly.
Advice on what I need to/can do?
Simon
85' Carrera 3.2
02' Mazda MX5
Old 06-24-2005, 01:25 AM
greglepore's Avatar
Not much, now. You can try a little touchup clear just to seal.
Common problem, can sometimes be avoided by heating the paint gently prior to rolling.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 06-24-2005, 05:41 AM
}{arlequin's Avatar
"gently" can be taken different ways
my paint cracked after I used a heatgun on the lip
others had success w/ a..... torch!
so the moral is, you have to really heat up the paint... almost to melting point? (I guess)
oh, flake off as much paint as you can (it already happened) then seal it, either w/ Por-15 and touch up, or w/ some clear coat/touch up combo.
dave
1973,5
Old 06-24-2005, 05:46 AM
Bill Verburg's Avatar
Depends on how bad it is, but I would have the area repainted and reseales on the back side.
This is a reason why i much prefer to cut the lips off. you will only need to reseal the edge.
Bill Verburg
Old 06-24-2005, 05:50 AM
ruf-porsche's Avatar
Another reason not to roll the fender.
Old 06-24-2005, 06:45 AM
Well I used my touch up paint and "plugged" up the little slits. Not sure that's the best solution but it's the coward's way out for now. Will sleep on everyone's advice.
Simon
85' Carrera 3.2
02' Mazda MX5
Old 06-24-2005, 07:19 AM
In the future one may consider using a pint pen and a clear as a final sealer. TowerPaint.com sells the pen matched to your paint.
Warren & Ron, may you rest in Peace.
Old 06-24-2005, 07:22 AM
Send a message via AIM to NoLift911
Bill what tool is used for your preferred method of doing this?
-Jeff
Jeff
Old 06-24-2005, 07:47 AM
