biosurfer1's Avatar
couple questions...any help would be great
so my simple heater hose replacement has turned into quite the chore and i have some questions...
First, i have a smog pump that makes it almost impossible to attach the heater hose to the inlet under it, i really cant see a way to hook the hose up there besides taking the smog pump completely out, any ideas?
next, i pulled some of my fuel injectors out to make room to take the heater blower out and now one of them wont go back in, all of the other i pushed in and they seemed to "snap" in around the o-ring, but this last one wont, i cant see anything blocking the opening, so whats up? would it be ok to put a little grease on the o-ring to help it along?
i also pulled a vacuum hose off from some place and cant seem to figure out where it goes, is there a diagram someplace so i can find out where to put it back on, it makes the car start like crap and backfire during warmup, its happened before ,but i cant remember where it went.
i'm sure there were more but i'm too frustrated that this turned into a huge ordeal to remember. Thanks!
1992 968 Polar Silver
2010 Toyota Highlander SE
2006 Lexus LS430 ML
Old 06-26-2005, 12:00 PM
AFJuvat's Avatar
Sorry, the smog pump is coning out. Sometimes you can get it in with the pump attached, other times you can't. If you keep fighting it, you will eventually screw up your new hose.
Use a little silicone lubricant on the fuel injector O-ring
Where abouts is the vacuum hose - if it is at the front of the motor, make sure that your vacuum hose to your distributor is installed.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 06-26-2005, 12:36 PM
lateapex911's Avatar
Hey Bio- I'm not an SC expert, but maybe your answer migth lie here:http://www.pelicanparts.com/911/911_Parts/911_1978-83_parts.htm
A little poking around will hopefully yeild the vacuum line answer. Good luck!
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 06-26-2005, 01:01 PM
Registered abUser
TerryH's Avatar
Removing the smog pump takes about 90 seconds. There is only one bolt, one hose, and a bracket to the coil bolt. You can leave the Y mount and plumb around it easily.
Yes, soap up the injector o-ring or replace it.
'81 911SC Coupe SOLD
Old 06-26-2005, 01:13 PM
