-   -   Any paint which changes color w/ temp? (http://forums.pelicanparts.com/porsche-911-technical-forum/228010-any-paint-changes-color-w-temp.html)
69911e 06-24-2005 10:11 AM
Anyone know of a paint or coating which changes color with temperature? Ideally, black at room temp, and red at temps above 125F. Must be able to take high temps.
EdSmileWavy
Jeff Alton 06-24-2005 10:50 AM
Brembo has some I think that does something similar, not sure about the heat ranges though.........
Jeff
911pcars 06-24-2005 10:55 AM
Contact a welding supply store. They have temp. indicating paint and crayon.
Also check with Racers Wholesale, Pegasus Racing. Also an industrial supplier like McMaster or Grainger Industrial Supplies.
Sherwood
http://members.rennlist.org/911pcars
kycarguy 935 06-24-2005 10:57 AM
This would be a company to try. I havent used then yet, and have no affiliation.
http://www.alsacorp.com/
http://www.alsacorp.com/paints.htm
http://www.alsacorp.com/products/xposurepaint/xposurepaint_prodinfo.htm
Xposures® is the first coating of its kind that can be sprayed. Remember the mood ring? Well it is like that but 1 million times better. Xposures® can be sprayed, roller applied, brushed, or even silk-screened. It only reacts to heat and or sun, and achieves the most dramatic looks over dark bases, especially black.
Xposures® can be applied to virtually any substrate including:
1. Plastics The true uniqueness is the fact that there are actually 8 colors that literally change before your eyes, making Xposures® the most spectacular coating ever made.
2. Metals
3. Fabrics
4. Leathers
5. Wood
6. Glass
Jack Olsen 06-24-2005 11:08 AM
I think the paints that do this are one-use deals. Once they change, they don't change back.
You could also use temperature-sensitive decals. They have a dot that changes color when you hit a particular temperature.
http://www.mcmaster.com/catalog/108/...l/5950kc1s.gif
They're stick-on nonreversible horizontal 4-temp labels with a range of 175 F to 250 F degrees. Packs of ten of them sell for $14 here.
Look for part number 5951K44 for the one pictured, and then click on 'catalog page' to see all your options. They probably also have ones for lower temp ranges.
GIBSON 06-24-2005 11:20 AM
Excuse the hijack here but I've got a paint story that just happened to me. I bought Stoddard's exhaust paint for early heat exchangers and muffler, took the entire exhaust system off to paint it and it looked great. The original darker grey that's hard to replicate in other ways. After 30 minutes of driving the car it turned an gawd-awful copper color. I called Stoddard and they said they couldn't believe it but they'd look into it. I heard from them a couple days later and they were really embarrassed.
The paint supplier had sold them 200 degree paint instead of the 1500 degree type. 2 or 3 months later I finally got my new paint.
Just finished spraying it on so we'll see if it's the right stuff. Have not driven the car yet.
Couldn't resist throwing this one in this thread.
randywebb 06-24-2005 11:32 AM
Is this a cosmetic thing? Or do you want to see temp. changes? If the latter, contact Omega Insturments - their catalog is a gold mine of useful tips and info.
69911e 06-24-2005 02:15 PM
Not cosmetic. I am looking for an automatically reseting high temp indicator.
Thanks for the suggestions.
ED
911pcars 06-24-2005 02:37 PM
Or you could connect a thermocouple to the area to be measured (if convenient) and run the wire to a multimeter that has a temp. display function (Fluke and many others).
Sherwood
randywebb 06-24-2005 07:10 PM
yes - you may want to use a fine wire T'cpl if the area has heat or solar radiation on it. Post more about the area nd the conditions...
to use a multimeter as a reader you need Type K
Remember -- a thermal sensor tells you the temp. of the Sensor itself -- whether that is the temp. of what you want measured is UP TO YOU
slater 06-25-2005 11:19 PM
270 bucks for a 2oz kit! Yikes! I second Jack's sticker idea, they are all over the helicopters I fly, and are very quick and easy.
scottb 06-26-2005 10:39 AM
Slater: When I trained, they were all over the R22 I was using. What are you flying?
Scott
slater 06-26-2005 12:17 PM
Scott- You called it! Flying R22's right now, just starting on my CFI rating.
scottb 06-26-2005 12:19 PM
Slater: Got my private in 3/94. Got the 47 in 7/94. Have been flying ever since ! Have fun. Be safe.
slater 06-26-2005 12:45 PM
Thanks, you too!
