another round please
strupgolf's Avatar
pre-muffler only--is it toooo loud
Does anyone run just a pre-muffler and short pipe without a muffler?. I would like to know if those alone are too loud for everyday driving, or is it really great for anytime. Im going to change my exhaust soon, so give me some ideas. The stock, 86 3.2 is nice, but I want louder. Thanks
Getting old is not for wimps.
Old 06-24-2005, 02:09 PM
She/Her
BeauBlues's Avatar
You might want to check with your local noise laws first. Also you don't need to run it without a muffler to make it louder. There are plenty of mufflers out there that will make it sound loud and nice without being "too loud"
Gwyneth *she/her
1995 993 Guards Red
1984 911 Targa with a G50 (RIP)
Old 06-24-2005, 02:12 PM
MAGA
Tim Hancock's Avatar
I just tried it when I had my muffler off and it is way toooooooooo loud!
Don't take my word though pull your muffler off and try it. No doubt you will agree. I ended up adding a 2 1/4" dia second outlet on the right side of my stock muffler and it sounds pretty good and is definitely louder. The straight out of the pre-muff though,is just not workable.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 06-24-2005, 02:29 PM
Unregistered
sammyg2's Avatar
I'm glad I don't live in your neighborhood.
Old 06-24-2005, 03:17 PM
I'd love to hear Tim's car. I've been told to add a second outlet to the stock muffler. Sound is improved (made louder) at a small cost like about $50. I'd also like to know if performance was improved or degraded. As much as I like loud (that's what almost 40 years of Grateful Dead concerts does to you) I'd like something lighter then the stock muffler. That assumes the stock muffler is heavy. If it is heavy than maybe a premuffler with a glass pack or how about a pair of glass packs in place of both the premuffler and muffler?
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not.
2012 BMW 528i (wife's)
2007 Toyota FJ (rain and off road days)
Old 06-24-2005, 04:13 PM
Large Registered Member
PatrickB's Avatar
I ran a bypass pipe (no more cat) into the stock muffler.... Deeper louder sound, with noticeable performance improvement!!
'85 Carrera Coupe, Marble Grey #118 JP/R6
'93 Lexus SC400, '00 Ford F-150
'70 911T- 2.7 (SOLD)
Old 06-24-2005, 05:47 PM
MAGA
I ran some second gear 30-60 mph timed tests before and after (see my DIY dyno post), my times were basically identical. I made a pair of flanges. I welded one to a 1/2" long 2 1/4" stub welded to my 2 1/4 hole I cut in the muffler on the right side. I made a second tail pipe to match my left one and welded it to my other flange.
I wanted the option to insert a plate w/ a smaller opening in case the 2 1/4" dia hole was too much. Then I added some stainless tips to finish it off.
It sounds alot more aggressive but not too loud.
I will post pictures of the whole affair on Monday morning, because my dial up connection at home is too slow.
0% Liberal
Old 06-24-2005, 06:10 PM
strupgolf's Avatar
Thanks guys. I now run stock muffler, with no cat, just a "test pipe". Thats a good idea to run a second outlet off the right. The more I think about it, it would be too loud since the premuffler is just a straight pipe. Now my second question. Has anyone "gutted" their stock muffler? I did see a thread on this a while back, but dont know the sound. I might just buy a mb911 and call it good. But, its fun to fiddle.
Old 06-24-2005, 06:55 PM
MAGA
Ben's muffler is made of top notch materials and someday I will probably have one, but being a hard core DIY tinkerer type I just have to experiment some times.
My cat was all ready gutted, but I added an internal perforated tube surrounded by some packing to emulate a premuffler. When I cut the hole in my stock muffler, the insides did not look like previous posts on presumably earlier style mufflers. Mine had a 180 degree bent perforated tube surrounded by packing in the right side chamber. I pulled the packing out of this area before I welded the new outlet flange on. I will post pictures on Monday.
0% Liberal
Old 06-25-2005, 04:55 AM
