Broken case need opinions
I have attached a few pics of my 77 7R case. The two areas in question are on the front of the block and both house studs for a cover. Is my case shot? I does not appear that there is a structral integrity issue but I really dont know. It looks like I can machine the two areas enough to bolt the cover together so it will not leak, will that make the case weaker and cause a failure? Please look at the photos and let me know if there is a serious issue or if anything can be done to strengthen the case.
Mike
BTW it appears I have figured out my pic posting issues.
79SC driver
77S targa work in progress
Old 06-26-2005, 07:21 PM
Air Medal or two
afterburn 549's Avatar
proper shop can fix that as good as new
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 06-26-2005, 08:59 PM
I had a two large holes and my case and my local weld specialist just heli-arc welded and it was like knew. It should not be a problem.
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 06-26-2005, 09:44 PM
Super Moderator
cstreit's Avatar
Can be welded, just be sure the guy is comfortable and experienced with magnesium!
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 06-26-2005, 09:59 PM
The bummer of it is I do not have the pieces to weld back in, it was like this when I brought it home. Could it be filled in drilled and tapped?
The real issue I see is the cover leaking. There is enough room to make a flat spot and use a nut and bolt to seal the cover. I dont want the thing to crack under heavy load, When I get back I will console a fab guy I know.
Mike
79SC driver
Old 06-27-2005, 02:55 AM
Irrationally exuberant
ChrisBennet's Avatar
The housing that the covers the pulley supports the back/fan end of the motor. It isn't a cover in the sense that if you removed it you'd have oil coming out. Are you have oil leak out of the broken hole or something?
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 06-27-2005, 04:00 AM
Chris,
I see what you mean. It covers the bottom pulley and doesnt hold oil, it bolt to the motor mount. This is structral I think I'm screwed.
Mike
79SC driver
Old 06-27-2005, 04:14 AM
Wildman Emeritus
Only screwed in the sense that it will need to be disassembled to be repaired properly. A welder will build the area with material & it will have to be machined flaton the mating surface & will have to be drilled & tapped. I can recommend a magnesium welding source for the welding if you wish, PM me.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 06-27-2005, 04:56 AM
CindyDuck,
When I bought my 1975, the same bolts holding the engine mount to the case were loose, and two had broken off in the case. This is a typical sign, and a typical location of the studs pulling the threads out of the engine case.
Rex
1975 911s
1997 Saab 900s
Old 06-27-2005, 05:09 AM
