farmer's Avatar
lowering to euro spec's question
what are the euro ride height spec's for a SC and how would you get that ride height and also, is there really a extreme handling change with this
thx farmer
slow down your going to fast!
where around that last corner are this one
Old 06-27-2005, 01:41 AM
}{arlequin's Avatar
heh heh... release the hounds!
dave
1973,5
Old 06-27-2005, 01:43 AM
The Spec Book gives values for:
Front axel
Height adjustment:
Wheel center above
middle of torsion bar
911 SC.(Euro)..................108mm
911 SC - USA................... 99mm
_______
9mm or .354"= 1/3" higher for US models
Rear Axel Secifications:
Height adjustment
Wheel center below center of cross tube
911 SC (Euro)...................16mm
911 SC/Turbo - USA,
Canada, Japan..................37mm
21mm difference between Euro and US or .826" higher for US.
Joe
Old 06-27-2005, 11:04 AM
Now in 993 land ...
aigel's Avatar
No extreme handling change but do it for the looks if nothing else. Note that the thick washers on top of the front struts have to come out to keep the proper geometry. They were put there only for the US ride height cars.
George
81 SC (sold)
Old 06-27-2005, 11:14 AM
anthony's Avatar
Euro ride height measured from the fenders is roughly 25.5" front, 25" rear.
Don't get too wild with the lowering. I actually raised the front of my car to 25.5" and the ride improved dramatically. The previous owner slammed the car down as low as it would go and there was zero suspension travel left.
After you lower the car you should get it aligned by a shop that knows 911s.
-Anthony Siino
1981 911SC
1974 914 2.0L
Old 06-27-2005, 11:51 AM
farmer's Avatar
thx for the spec's guy's
Old 06-27-2005, 05:19 PM
