Derek911's Avatar
Penetrating oil effectivness
I found this surfing the web. I have no affiliation with the testing, I just found it interesting. Since we live in a world of rusted nuts and bolts and would basically do anything to make things easier or avoid broken studs, here is the info.
Machinist's Workshop MagT recently published some information on various penetrating oils. The magazine reports they tested penetrates for break out torque on rusted nuts.They are below. They arranged a subjective test of all the popular penetrates with the control being the torque required to remove the nut from a "scientifically rusted" environment.
Penetrating oils ........... Average torque load to loosen
No Oil used ................... 516 pounds
WD-40 ..................... ... 238 pounds
PB Blaster .................... 214 pounds
Liquid Wrench ...............127 pounds
Kano Kroil .................... 106 pounds
ATF*-Acetone mix............53 pounds
The ATF-Acetone mix is a "home brew" mix of 50 - 50 automatic transmission fluid and acetone. Note this "home brew" released bolts better than any commercial product in this one particular test.
ATF-Acetone mix is best, but you can also use ATF and lacquer thinner in a 50-50 mix.
*ATF=Automatic Transmission Fluid.
Old 11-06-2014, 04:57 AM
Derek911's Avatar
Another thing to add... I usually don't buy anything until I read reviews of the product from Amazon.com. I find the reviews the best guide to how well a product works or is. I have never even heard of Kano Kroil, so I looked it up on Amazon and the reviews are very good. Just more food for thought. I have to try it.
Old 11-06-2014, 05:04 AM
82 SC's Avatar
I wonder how Wurth Rost Off is compared to these? Seems pretty good to me. Thanks for posting this as I think I will make a batch of ATF-mix when all my other stuff runs out
1982 SC "Spooky"
1961 VW Single cab truck
1966 VW Deluxe Hard top
Old 11-06-2014, 05:10 AM
I'll try the ATF mix on my next challenge. One to add as a last resort:
acetylene torch ................ 0 pounds
Chuck.H
'89 TurboLookTarga, 384k miles
Old 11-06-2014, 05:20 AM
I heard about ATF & Acetone in here a couple of years ago and thought I would try it back then.
I am still using this method because it really works.
I just mix it up as I need it as the acetone evaporates quickly.
You can store it mixed in an airtight container but fresh seems best.
Just my 2c.
Cheers
Bill
1977 Carrera 3.0
This much fun must be illegal!
Old 11-06-2014, 05:46 AM
+1 on ARF/Acetone
About a year ago, I removed my fuel distributor while doing some other projects on the car. I made the mistake of letting it sit on a shelf in the garage for 3 months and the piston froze up. It was in a Ziploc bag but I should have oiled it first. Instead, I had cleaned it with carb cleaner then let it sit for months.
I tried soaking in various penetrating oils for weeks but the piston would not budge. I even tried to move the piston with various tools but it was frozen solid.
I read about the ATF/Acetone on this board and decided to try it. I applied to the piston and within 15 seconds the piston fell out. It was so fast that it almost hit the floor but I caught it. It literally was a miracle and that is what I will use forever!
Old 11-06-2014, 06:07 AM
TheSt|G's Avatar
I'm surprised WD40 did that much.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 11-06-2014, 06:24 AM
I am very familiar with the Kano Kroil and it works the best, thus far, for me... and i'm talking exhaust studs, heads, and working on the 356 suspension - which once in a while you get to places where nobody's been in 50 years... HOWEVER, never try this mix BUT I will and feedback you guys.
Old 11-06-2014, 06:55 AM
cashman's Avatar
This same report has been posted several times over the years. I know because I just bought some Kroil and read all the threads doing my research .
General summary:
Kroil is the best. Mixed reviews on the ATF/Acetone. Some stated Liquid Wrench was good but that was pretty much disputed by a lot of people.
I just received my Kroil and haven't had any need to try it. I did try the ATF/Acetone mix in the past and didn't notice anything miraculous.
This is what I bought for those interested:
Special Deal on Kroil
1989 911 Carrera Cab
25th Anniversary Edition
Euro Pre-Muffler, SW Chip
There's nothing better than: Listening to "Going Down the Road Feeling Bad" ,as I, "Go Down the Road Feeling Bad"
Old 11-06-2014, 07:36 AM
SCadaddle's Avatar
I remember it was more than a year ago when I came across this "info". For the past several years my Porsche and VW friends have been using Kroil. So one night with my VW friends we mixed up a batch of the magical acetone/transmission fluid and tried it on some VW heat exchanger to head nuts. Sprayed one side with Kroil, the other with the "magic concoction". An hour later in walks Bill the machinist. He gets handed a wrench in a "blind force test" and clearly, Kroil was the winner. IMHO either that "info" is a bunch of junk that needs to find a home on Snopes or there are a lot of people who have never used Kroil.
Old 11-06-2014, 08:11 AM
82 SC's Avatar
seems this has been around awhile.
Penetrating Oil Test -
1982 SC "Spooky"
Old 11-06-2014, 08:25 AM
Uncertifiable!!!
Uwon's Avatar
I use a 50/50 mix is AFT and rubbing alcohol, the later being cheaper than acetone. Works for me. You still have to be careful with nearby painted surfaces
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 11-07-2014, 11:54 AM
kodioneill's Avatar
I tried the ATF acetone mix Man it stinks something awful. I thought the standard stuff worked just as well.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 11-07-2014, 12:29 PM
88 Carrera, Guards Red
azhodge's Avatar
I am going to mix up some of the atf-acetone. trying to figure out what to store it in that 1) won't let the acetone evaporate. and 2) will allow me to squirt it on the area. 3) acetone won't melt it... any suggestions??
Old 12-08-2014, 06:26 PM
What are you waiting for? If you recently purchased one of these products and haven't tried it yet, apply some to the exhaust nuts/studs even though you're not going to remove them. The oil will penetrate the threads and either help break up any corrosion and/or keep the threads lubed. You may thank this writer later when you remove them without breaking/bending/distorting anything. Our engines are full of dissimilar metals in intimate contact with one another.
However, some penetrating oils are better than others. FWIW, My vote is for AeroKroil. The deal in the link is good, otherwise you have to buy a case of the expensive stuff. Split the order with a friend.
Sherwood
Old 12-08-2014, 08:58 PM
964TargaC2's Avatar
Where does Gibbs fall in?
I think that maybe I'm dreaming..
Old 12-08-2014, 09:23 PM
SoCalSK8r's Avatar
I swear by Kroil but haven't tried the acetone/ate mix
‘84 Carrera, heavily modded
Please follow me @chopped_up_fitness
Old 12-08-2014, 09:37 PM
Derek911's Avatar
Goldenrod Pistol Pump Oiler - 6in., Model# 606:Amazon:Industrial & Scientific
I use this oil pump from Amazon. It is very well made, no plastic, and small enough to use and get into tight spaces. Metal flexible tip and it squirts really far. Kroil comes in a spray or pour can. I use this pump for kroil or any other oil mix. The spray is very precise and not messy. You can put down a drop or squirt it a distance.
Old 12-09-2014, 06:27 AM
Dave Colangelo's Avatar
I have tried a variety of these concoctions over the years and they all work well, I generally stick to PB Blaster just out of habit and I don't have to mix it up my self. I also have never had any issues with it eating other things away.
Just a word of advice, although strong solvents may work well you need to be careful as they can sometimes damage rubber parts and exterior finish near the area you are spraying.
In the end of the day a good breaker bar or impact wrench will generally do the job. This is one of those times is often better to have the right tool on hand than to try and over use solvents instead. When all else fails some good old elbow grease is often what it takes. On an interesting note, if properly torqued most bolts on these cars should not be that hard to remove but often times PO's, bad mechanics or a mix of the two really wail on the stuff. A buddy of mine bought a 924 and we could not get the oil drain bolt off with a 4 ft. breaker bar...
Regards
Dave
'78 911SC Targa (Back In Action!)
'00 996 Carrera (New kid on the block)
'87 944 (college DD - SOLD)
'88 924s (high school DD - Gone to a better home)
Old 12-09-2014, 06:58 AM
In some cases, a 6' pipe/handle extension is necessary. However, a skilled/experienced tech will choose the correct tool/technique depending on the task at hand. Using brute force when a more effective technique is available invites potentially unnecessary damage. Ever try brute force on exhaust fasteners that are environmentally welded to each other?
Sherwood
Old 12-09-2014, 10:24 AM
