Turbo guru's needed
Im collecting parts for my turbo "project" and relized I dont have a clue as to which of these is the oil feed hole and the oil return hole. Can you guys help me out?
http://forums.pelicanparts.com/uploa...1119975052.jpg |
Based on what I can see in the picture and what I know from playing with turbos, the flange (top arrow in your picture) is prolly the oil drain and needs to be at the bottom, or within a few degrees from bottom. the oil feed should be 180 from the flange and is threaded for a fitting. It looks like you have a garrett? turbo, and if so the side taps are for water cooling and should be plugged in an air cooled application.
Its a garrett T4 Super-60 .42 intake/.48 exhaust. And thank you.
Not that I'm a guru but that looks like watercooled turbo. Top arrow looks like oil-drain and bottom arrow is water input or output. Looks like custom turbo from some passenger car with that 90-degree elbow just behind the turbine...which car is thing going into?
I'm going to put it on the 318i bmw. I just got the exhaust manifold and the FMU. Still need bigger injectors. I'm going to run it without an intercooler at first and then add one later.
So where is the return hole? |
Here's the other sidehttp://forums.pelicanparts.com/uploa...1119978181.jpg
It doesn't matter which way you push water trough it...oil input is top one on second picture and oil-drain is top on first picture.
P.S. Vert¡cal line going trough oil flanges shouldn't tilt more than 15 deg. from vertical axle in any direction, according to Garrett specs.
Thanks beeper. Do you think I should get one that doesnt have the water cooling?
If you can run a water line to the turbo, it's a cooler running setup.
Rick '78 930 |
If it's going into a BMW, by all means hook up water to it.
If it was going in a 911 then you would plug the water ports. Oil in is the smaller round hole, oil out is the larger square hole. |
| All times are GMT -8. The time now is 07:07 AM. |
