Dansk Dual Muffler TOO Loud - What Can I Do?
Just installed a new single in - dual out muffler on my 88 Cab & man, it's loud.
Is there any way I can reduce some of the noise & Keep the following:
The Same HP gain?
The original (dual) look?
Old 05-26-2005, 12:24 PM
PorscheRyan911's Avatar
Keep it loud!!!!
Stock White 1971 911T Targa
Old 05-26-2005, 12:28 PM
Certified Pre-Owned
BGCarrera32's Avatar
I switched from a factory Carrera exhaust to a single in dual out Dansk and if its *that* loud you have a problem with it...
'84 Carrera Coupe
Old 05-26-2005, 12:31 PM
ianc's Avatar
Stick a banana in the tail pipe.
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 05-26-2005, 12:37 PM
Others have suggested using baffles available from motorcycle shops or other sources.
Other possible solutions as posted by others:
http://www.carchemistry.com/ccinserts.html
http://www.carchemistry.com/ccflanged_inserts.html
Tailpipe insert:
Header insert:
Warren & Ron, may you rest in Peace.
Old 05-26-2005, 12:39 PM
Send a message via AIM to NoLift911
Sure it is not leaking?? - I found the Dansk to be tame - much more so than the RUF Dual out Sport...on my 84 3.2
-Jeff
Jeff
Old 05-26-2005, 12:46 PM
Bye, Bye.
Scooter's Avatar
My Dansk was just right. Not too loud in the cockpit, but a nice rumble on the outside. I agree with the thoughts above, if it is too loud, you may have a leak. If no leak and still too loud, then take it off and get something quieter. Earplugs work great too!
Elvis has left the building.
Old 05-26-2005, 01:27 PM
Certified Pre-Owned
It is possible that you have a leak at the seam where the 2 halves of the banana can is welded together. If you look at the factory Bischoff muffler there is a continuous flow weld all the way around the seam of the muffler. Not so with the Dansk...the lip is spot welded together every few millimeters with multiple spot welds to hold it together at the seam. Clearly a faster and cost cutting way to weld the unit together. I received one of them that had a 2" long section at the seam that you could pass a .020" feeler gauge through to the inside of the muffler. The spot welds never pinched the seam together in this area, probably due to some hunk of weld slag or crap on the metal, hence the leak. The Dansk rep was kind enough to work with me on it and get it resolved, but I still ended up zipping the seam on the backside of the replacement one shut with my tig welder. Suffice it to say I will not be to quick to purchse another Dansk...yet I honestly haven't seen and non-factory units that really impress me with fit and finish either. Outside of the factory equipment I really question quality control from some manufacturers.
'84 Carrera Coupe
Old 05-26-2005, 01:37 PM
JBO JBO is offline
...no such thing as too loud...
Old 05-26-2005, 01:43 PM
911mot's Avatar
Turn the stereo up
1984 3.2 Carrera
Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o
Old 05-26-2005, 02:10 PM
GettinHeadStuds's Avatar
ianc
We're not going to fall for the banana in the tail pipe...
83 SC (gone) / 72 T (gone)
Old 05-26-2005, 02:35 PM
Go with GHL, you will be happier
911 1987 Triple Black Cab Turbo Look >> weekend car
SPF MK III Shelby Cobra 427 550HP >> thrill for speed
BMW 88 635CSi daily drive
BMW 87 325i use for rainning day (donation)
Benz 06 E350 use for pick-up kid on car pool day
Old 05-26-2005, 02:46 PM
Bello,
What you could do is have a SS fabricator fab a delete for one side of the exhaust.
I run a Borla dual in quad out.
When it is open, man she screams, but there also is alot of ressonance in daily driving. What I did was I took the muffler to a local fabricator and he created a cap that I am extremely happy with.
I capped the passenger side, which eliminated the ressonance, but still has a great sound to it. and when I want, I can take it off and wake the neighbors.
Jeremy C.
Why's he calling me meat? I'm the one driving a Porsche. (Bull Durham)
----Nothing is far away in this car!---
-2001 996 Turbo
Old 05-26-2005, 03:07 PM
You can by tips with baffles in them
Old 05-26-2005, 03:10 PM
I agree, its too loud. Sell it to me, I'll even take the banana
Bill
1987 Marine Blue 911 Carrera Coupe RIP 01/2011
1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint
Old 05-26-2005, 05:47 PM
You guys are killling me. this topic has been shoed to death in the past. the monty muffler is the best for quality, cool exhaust tone and sound,
minimal cock pit resonance and is the official dyno tested and approved muffler for true power band and torque with accountable horse power gains and is the muffler of choice from makers of SSI of Novato, Californa... but i still love ta read how the other mfg's are still making what they make.
antares
fatnwide
Old 05-27-2005, 12:52 AM
dickster's Avatar
I dont believe he has a leak. Mine's also loud - for me. Sounds great gunning it, but at low/mid rpm you have to raise your voice slightly to have a conversation.
I would like to try a Monty, but for the $$$ the Dansk is hard to beat.
Rich
'86 coupe
"there you are"
Old 05-27-2005, 01:30 AM
he can cut down the high frequencies in the cabin with about 25lbs of Dynamat.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-27-2005, 04:42 AM
Type911's Avatar
antares
fatnwide
What he said
Old 05-27-2005, 05:22 AM
randywebb's Avatar
As RickM noted tailpipe inserts will be cheapest. You will likely lose some hp - if you want to know how much - then measure.
antares noted that a switch to the Monty is the real solution - tho it is not cheap. You could sell the old used muffler for __? $150 maybe? $200?
I have not seen dyno data on Ben's muffler - it looks good and is about 1/2 the price of the Monty. It's worth investigation. For the price you could buy it, test it, and if unhappy not be out too many sheckels - plus you could resell it as only slightly used.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 05-27-2005, 01:50 PM
