best "key on" power source under seat
before l do things my way l thought l`d post about this.l`ve added a PLX wideband system and some other items which require a key on power source. l`ve located the respective modules under the drivers seat for a number of reasons and since there`s key on power already there for the relay and ECM it seems a good fit.The question though is where would you draw power from under the seat.l don`t think the PLX or FP guage module have high power requirements looking at the feed wires.Nothing is stated in the destructions either.Any help appreciated
as always
my life begins at 150MPH |
RETIRED
I would run a line to the fuse box with another inline fuse.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
l considered going off the fuel pump circuit also.This wouldn`t be a key on power but that would be fine for this application. l`m always looking for a better way....
Save yourself or the next owner some trouble - go with the fuse box. What I've tried to do when wiring accessories is go off a fuse for something non-essential. If your accessory malfunctions, the fuel pump isn't something you want acting up. Likewise headlights, etc. There's a fuse in there for things like electric mirror adjust, seat heating, cigarette lighter, etc. I'd use that. and fuse it, as Mike suggests.
89 Carrera 3.4 "There is a right way to go around a corner - it's called the line." -- PCA DE speaker bryteside.com - good things happen. |
l`ll probably do that,thanks amigos.With all the extra electronics l`ve added it`s a challange to keep things simple,clean and easy to understand down the road.l try to use OEM wiring and connectors from wrecked cars if possible.
