How to remove Head temp sensor?????
Rebuilding my 3.2 with 156,000 miles.During teardown,got to pulling sensors,switches,etc. from engine.Head temp. sensor is installed into pocket on side of head & has attached wire on sensor.Because of wire,can't use regular deep well socket,b/c of clearance around sensor can't get boxend wrench or open end on it either:mad: Sent heads & cams to EBS with sensor still in.Apparently,they had issue getting it out also.Ruined sensor in process.Oh Well,add $59 to the tab.What is correct tool for this??
Best as I could judge,something like a o2 sensor socket w/ a slot cut out would appear to work but couldn't find one in correct size which is 14mm??Do I need to sacrifice a 14mm deepwell to the cause or anyone know where to find one.Have looked around some,Craftsman,Snap-On,McMaster-Carr etc....No Luck:( Anyone????? Just talked to Don @ EBS.....all new valves needed....so much for the budget rebuild:D |
These can probably be purchased from Snap-On, Matco, etc., but for the $$ difference and time expended, I'd suggest a Craftsman 14mm, 6 pt. deep sockect and cut a slot up the side for this project. We use this setup at the shop and it works just fine.
Did check the snap-on catalog @ work.Didn't see it in there.Thats ok.Found an older 14mm socket to modify.Thanks for the response.
Chris |
I purchased mine from Snap-On....
Here's a pic. http://forums.pelicanparts.com/uploa...1120139135.gif http://forums.pelicanparts.com/uploa...1120139233.gif |
Thanks for the info everyone!Will be ready when heads return!
Chris |
Snap-On part number:
FRXM14 |
If you are going to replace the sensor anyway, you can just cut the wire and use a normal socket.
Alan is right.
Chop wires and use a socket. I did. Ned |
I just cut a box end wrench, 14 mm or if you do not have metric, use a 9/16. Cut a slot into the box end to pass the wire through. Works great.
Jeff |
I'm With CATCA...
I used a 6 point 9/16" deep socket and chop sawed a slot in it stopping just prior to the square drive... |
all the heads have a sensor hole, so you can use any of them as #3. be careful not to tighten the new one too much. they snap off. then you have to get the threaded part out again.
| All times are GMT -8. The time now is 02:35 AM. |
