Steering wheel wobbles.....and getting worse!
About a week ago I noticed that the steering wheel had a little up & down play. Seemed like about 1/8" yesterday it had increased to more like 3/8"
This can't be good. Fortunately I did a search and found several threads and a tech article on replacing the steering shaft bushing. From the tech article photos it looks exactly like what could cause the steering shaft to wobble the way it does. So I've ordered the new bushing which will take about week to get here. My question is - is there any danger in continuing to drive it in the mean time? Can it cause damage to other components? Could I lose steering ability by something binding up in there?
1986 Carrera Coupe 1999 Chevy Tahoe 1987 Chevy Blazer 1955 Chevy Apache 3100 Pickup "A little knowledge is a dangerous thing" |
Up and down in this case means radially along the diameter of the bearing, right?
No danger, just annoyance, if that is the case. Up and down toward your chest is another matter.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Thats' right it's radially along the bearing diameter not towards the driver.
barrpete,
you'll be fine..the bushing should tighten the play right up.. ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
Check is the steering wheel nut are loosed.
1972 911T 1991 Mazda RX-7 Turbo II Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life! |
This is a simple problem. You need to order a steering wheel bushing from our host; remove the wheel and slide the bushing onto the steering shaft. 20 minute job. I did mine in a mall parking lot waiting on my wife. Covered in past threads and I believe in Wayne's book.
Good luck, Ben |
Thanks for the feedback guys. You've confirmed what I hoped was the situation. And amazingly enough this fix looks simple AND cheap! I have the part on order - should be here next Friday.
Nitrometano, Good point. I checked and I can see the that it's the steering shaft moving not just the wheel.
I just had the same problem last week. The original bushing went out when I was on the freeway, so I freaked out at first.
Anyway when I saw the nut was tight, I noticed the bushing was shot. I was acutally kind of impressed that the original one did last for 28 years... I bought one from our host which is metal and not plastic. Took no more than 10 min to put everything back together. Everything tightened right back up and will no longer have to worry about that. Good luck...
Jeremy C. Why's he calling me meat? I'm the one driving a Porsche. (Bull Durham) ----Nothing is far away in this car!--- -2001 996 Turbo |
