450knotOffice's Avatar
Spark plugs really can tell you a lot about your engine's health
I decided to replace my plugs, cap, and rotor today because I haven't done that since I've owned the car (5000 miles now) and I've been meaning to see how all the cylinders have been running. The plug wires are OEM and look good so they are staying put for now.
Anyway, I was pleased to find that all six plugs are a nice light grey color with no hot spots or dark soot anywhere. They're all about the same shade of grey too which tells me that the cylinders are all getting about the same fuel mixtures and running at about the same temperatures. The only thing I found wrong was the gap on all the plugs was WAY off on the high side. Spec is .7 to.8 mm and mine were all at 1.05 mm. That would give me a weaker spark and harder starting, I believe.
I have to say that I was a little worried that I might find evidence of oil getting past the valve guides, considering that worn guides are a well known Achilles heel of the 3.2 engine. No evidence of that at all, thankfully.
Anyway, I just wanted to pass that info along ( I know, wasting bandwidth). Spark plugs should be looked at more often by drivers because they can really tell you a lot about the health of your engine.
Old 07-03-2005, 02:16 PM
Zeke's Avatar
Heh, heh, tell me about it, I've got 3 black ones and 3 tan. Yours look teriffic for the type of engine you have. Happy 4th, Scott.
Old 07-03-2005, 02:25 PM
Thanks Milt. You too.
Old 07-03-2005, 02:28 PM
efhughes3's Avatar
I know what you mean-here are mine which I pulled while the motor was out a couple of months ago. I had about 4K on them, and the motor was right at 121K at the time. I was/am happy
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 07-03-2005, 05:09 PM
Those look really good. I replaced my copper Bosch plugs with their Platinum versions, like yours.
Engine feels a bit smoother (probably my imagination, I know)
Old 07-03-2005, 05:12 PM
Nitrometano's Avatar
Looks like lean condition in 3 cylinders
1972 911T
1991 Mazda RX-7 Turbo II
Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life!
Old 07-03-2005, 08:39 PM
bigchillcar's Avatar
been meaning to do this for several weeks..guess i'll have to tear up the knuckles tomorrow. thanks a lot, scott..
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 07-03-2005, 11:37 PM
