Thump at rear when accelerate!
Car is a Tip 996tt. I've been encountering a clunk at the rear sometimes when I accelerate from a low speed (around 30 mph at 3rd gear). Mechanic said the engine/tranny mounts are tight. The subframe is ok. The sway bar and U/CV joints are all ok. The "thump" doesn't happen all the time. Mechanic was unable to find the problem. Any idea?
Old 07-05-2005, 08:09 PM
Can anyone shed some light on this please?
Old 07-06-2005, 02:43 AM
Semper drive!
rcecale's Avatar
how about your rear-wheel bearings? Has your mech ruled those out?
Randy
84 944 - Alpine White
86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )
One Marine's View
Igitur qui desiderat pacem, praeparet bellum
Old 07-06-2005, 02:48 AM
Yep. Mech said they are ok.
Old 07-06-2005, 02:52 AM
How about a locked rear shock absorber? It happens often with the Konies, some folks say is due to the lack of use...
Old 07-06-2005, 01:59 PM
Could you describe it in more detail? a metallic "thunk" vs. a muffled "thump", general location, left/right wise, maybe it happens at a certain rpm, or a gear change?
89 Carrera 3.4
"There is a right way to go around a corner - it's called the line." -- PCA DE speaker
bryteside.com - good things happen.
Old 07-06-2005, 02:07 PM
87coupe's Avatar
Check out the handbrake, I've had mine not release fully - then while accellerating the last portion releases and makes a "thump".
ßrandon
Old 07-06-2005, 03:20 PM
Jeff Alton's Avatar
Does this car still have warranty?
Jeff
www.turn3autosport.com
Old 07-06-2005, 04:04 PM
Thanks guys. I've asked my mech to check the suspension and he said they are ok.
The sound is more like a metallic "thunk". The location of the "thunk" sound is from the rear around the engine area (it seems to come from underneath the engine, maybe from the exhaust). It doesn't happen all the time. Sometimes it happens when the car accelerate (not WOT) at a cruising speed of around 30 to 40 mph (at 3rd gear sometimes 4th gear, probably around 2000 rpm). The thunk sound does not seem to be from the transmission coz it is from the rear end of the car. Mech thinks that it could be a backfire. I am not sure if this "thunk" sound is actually describe by other people as "ping" in the engine (spark shock). Since I have been using high level octane gas so the sound shouldn't be the sound of a detonation (plus it doesn't happen all the time). Any views?
Old 07-06-2005, 07:39 PM
