Carrera Brake R&R
I've just returned from a 3 day track weekend and I'm doing some work on the stock Carrera brakes. Here's what I'm experiencing on brakes that are totally new within the last two years. I've done about 16 track days and 1500 street miles. New stock solid rotors, front brake cooling ducts, PF 97 pads, and rebuilt calipers.
Front pads 70%, rear pads 10% Outer caliper piston seals fried and crunchy on all four calipers. Inner seals seem rubbery and plyable Is this normal? How often will I have to rebuild the calipers? Why do the rears wear so fast? Anything I can do to extend the life of any of the components? John
1985.5 944 GTS |
The Carrera has more rear bias than earlier cars, the p/v is supposed to compenstae but only does so at line pressures >33bar
To use less rear brake you need to push harder for a shorter period of time, but don't jab the brake as that creates pressure spikes that are worse. The calipers saw temps of 400 - 1000°F or so and will need to be replaced after each track event unless you can get the rotor temps down and keep them there at all times. A Carrera is a very underbraked car for track use, if class rules allow 930 size or better rotors are the best way to reduce temps. Cooling helps but only marginally in this case.
I not doubting your expertise in general when it comes to brakes and their packaging and maybe I have misunderstood the intent of your comment, but I would query the fact that they need to be rebuilt after each track event. I've done two track days on my brakes that have not been rebuilt in the last 2 years at the very least (nor have I seen anything in the PO receipts that suggest that this has been done in the last 5yrs), where I have experienced very hot brakes to the point where they were fading excessively (i.e. 50% or more increase in pedal travel). To date there have appears to have no lasting issues, the brakes pull the car up fine with excellent pedal pressures and no leaks or funny noises. The only preparation I've done is to replace the brake fluid with AP Racing 551 fluid. Could you please restate the intention of the above comment?
Sheldon '92 964 Carrera 2 (Manual) '07 BMW 335i '76 911 Carrera 3.0 (Gone, but not forgotten) "Give me ambiguity or give me something else!" |
Bill,
Thanks for the input. I have never experienced fade so I assume they have never really gotten to the high end of the temperature range. I think I do a pretty good with my braking, but was wondering if these are normal attributes. I guess I'll rebuild the calipers, change pads and move on. Just wanted to make sure there were no other issues. John
1985.5 944 GTS |
a few minutes at 440°, will be ok the first time but not the tenth.
MBruns for President
With todays higher boiling point brake fluid it's easy to fry your caliper seals without getting fade. ask me how I know. Especially in a fat a$$ cabriolet.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes | Last edited by Bill Verburg; 07-26-2005 at 01:42 PM.. |
Typo: remove the 7 or a 0 from Bill's post above.
The Solar surface apparent radiative temperature is only 6,000 oF.... so I don't think the brake pads will withstand that temperature.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
RW Thanks, i was in a hurry and didn't proof it. Corrected now
no prob -- "keeping it real" if not "down to earth"
Ok so the seals go after X amount of high temp time. What about the rear pad wear, is that normal?
John
1985.5 944 GTS |
Sorry for the misunderstanding Bill, 400 degree caliper temps are obviously a whole lot different story to rotor temps - my bad.
