-   -   Turbo problem solved!!! (Funny) (http://forums.pelicanparts.com/porsche-911-technical-forum/230177-turbo-problem-solved-funny.html)
Gumba11 07-08-2005 07:20 PM
I finally found the perfect trim for the inducer wheel on my turbo. This should provide enough air!
http://forums.pelicanparts.com/uploa...1120875556.jpg
LOL....................................C:)
Paul K 07-08-2005 07:55 PM
So the question I have is...
Polish or powder coat?
Cheers!
Paul.
aturboman 07-08-2005 08:31 PM
Sales Pitch: "It's great for top end power but may have alittle more throttle lag than stock"
afterburn 549 07-08-2005 08:47 PM
do you run a internal or external wast gate??
Vipergrün 07-08-2005 09:49 PM
I see an E-Ram version in the near future......
Emission 07-08-2005 10:48 PM
"Once this baby spools up.... HAAAAAAANNNNNNGGGG OOOONNNN!
Lukesportsman 07-08-2005 11:10 PM
Can I still use the stock exhaust?
slow&rusty 07-09-2005 04:57 AM
That the is the stock turbo that came off one of these (I believe):
http://www.hondapowerequipment.com/i...7tda-large.jpg
Yasin
wholberg 07-09-2005 07:17 AM
So...what compression rings do you use for 2000 lbs of boost?
jjwood 07-09-2005 09:34 AM
Yea -- but what about twin turbos?
sammyg2 07-09-2005 10:08 AM
LOL, let me guess. 1st stage impeller off an Elliott or IR Centrifugal compressor, prolly a 3 or 4 stage unit. Used primarily in gas handling and seperation units (CO2, h2, etc).
Yep, I've rebuilt more than my share of those beasts, even spent some time at the factory in Jeanette, Pa.
Scary thing is, they have actually made some much bigger than that.
They have a concrete/steel lined vacuum test chamber where they spin em up for balance, then over speed em to make sure they don't fly apart. The vacuum chamber is almoast as big as my garage.
Emission 07-09-2005 01:48 PM
Is that thing titanium or stainless? Or ceramic? How heavy is it?
911pcars 07-09-2005 01:56 PM
I wonder how fast that must spin to generate boost? And how much boost?
Sherwood
sammyg2 07-09-2005 03:59 PM
On one that size is it is prolly limited to 16,000 rpm. the really small ones on the final stages spin as fast as 56,000 rpm.
They have a very large diamter bowl gear that spins at 3600, then the smaller pinion gears run off the bowl gear and spin the impellers.
The rpm of the impellers is determined by the diameter of the pinion gears.
Compression ratio on these things is usually designed for 3:1. So if a 1st stage has a suction pressure of 14.7 psia (atmospheric pressure), the discharge pressure should be around 45 to 50 psia, or 30 to 35 psig. The diameter determines the rate of flow, one that size is prolly on a 80,000 cfm machine. I'd guess the driver is rated at around 3000 hp.
Material of contruction is usually aluminium on the smaller ones and stainless steel alloys on the bigger ones.
The one in the picture prolly weighs close to 100#
Emission 07-09-2005 04:09 PM
Wow. Interesting technical data!
sammyg2 07-09-2005 05:15 PM
Uhhmm, really? I figured I was raining on everyone's parade by trying to be serious when they were cracking jokes ;)
I just couldn't think of anything funny to write :(
