I finally found the perfect trim for the inducer wheel on my turbo. This should provide enough air!
LOL....................................C
77 930 "P Zilla" 3.2 Litre w / EFI conversion |
So the question I have is...
Polish or powder coat? Cheers! Paul.
'85 Defender 90 V8 Station Wagon (mine), ‘16 Mini Cooper S Countryman All4, ‘79 Mini Moke Californian (hers). '83 SC Coupe SOLD '96 Carrera 4 Coupe SOLD '89 Carrera Targa SOLD |
Sales Pitch: "It's great for top end power but may have alittle more throttle lag than stock"
Air Medal or two
do you run a internal or external wast gate??
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
Formerly bb80sc
I see an E-Ram version in the near future......
Cheers -Brad 2015 Cayman GTS 2015 4Runner Limited |
Automotive Monomaniac
"Once this baby spools up.... HAAAAAAANNNNNNGGGG OOOONNNN!
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) |
Can I still use the stock exhaust?
Luke S. 72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT |
That the is the stock turbo that came off one of these (I believe):
![]() Yasin
Ole Skool - wouldn't have it any other way |
Wider is Better
So...what compression rings do you use for 2000 lbs of boost?
Wider is Better |
Yea -- but what about twin turbos?
Jeremy ![]() 1971 911 Wide One 2.7 2012 911 Cabriolet 2011 Cayenne S |
Unregistered
LOL, let me guess. 1st stage impeller off an Elliott or IR Centrifugal compressor, prolly a 3 or 4 stage unit. Used primarily in gas handling and seperation units (CO2, h2, etc).
Yep, I've rebuilt more than my share of those beasts, even spent some time at the factory in Jeanette, Pa. Scary thing is, they have actually made some much bigger than that. They have a concrete/steel lined vacuum test chamber where they spin em up for balance, then over speed em to make sure they don't fly apart. The vacuum chamber is almoast as big as my garage. |
Is that thing titanium or stainless? Or ceramic? How heavy is it?
I wonder how fast that must spin to generate boost? And how much boost?
Sherwood |
Unregistered
On one that size is it is prolly limited to 16,000 rpm. the really small ones on the final stages spin as fast as 56,000 rpm.
They have a very large diamter bowl gear that spins at 3600, then the smaller pinion gears run off the bowl gear and spin the impellers. The rpm of the impellers is determined by the diameter of the pinion gears. Compression ratio on these things is usually designed for 3:1. So if a 1st stage has a suction pressure of 14.7 psia (atmospheric pressure), the discharge pressure should be around 45 to 50 psia, or 30 to 35 psig. The diameter determines the rate of flow, one that size is prolly on a 80,000 cfm machine. I'd guess the driver is rated at around 3000 hp. Material of contruction is usually aluminium on the smaller ones and stainless steel alloys on the bigger ones. The one in the picture prolly weighs close to 100# |
Wow. Interesting technical data!
Unregistered
Uhhmm, really? I figured I was raining on everyone's parade by trying to be serious when they were cracking jokes
I just couldn't think of anything funny to write
