-   -   Installing a Engine Compartment Sound Mat (http://forums.pelicanparts.com/porsche-911-technical-forum/230642-installing-engine-compartment-sound-mat.html)
john4061 07-11-2005 06:04 PM
Does Anyone Know if there is an easy way to install a new engine compartment sound mat on a 1985 Porsche 911 Targa Carrera with out removing the engine? Mine is falling apart and I see Pelican parts sells a replacement.
randywebb 07-11-2005 06:06 PM
some remove stuff on top of the engine; others do a "partial drop"
many threads if you search
walt 07-11-2005 06:30 PM
A partial drop will make this job a lot easier. Just dropping the engine a few inches really makes a dramatic difference.
asphaltgambler 07-11-2005 06:38 PM
Do a search, much good info on this subject
azasadny 07-11-2005 08:34 PM
Partial engine drop is the way to go! Very easy and you can inspect/replace hoses, fuel lines, clamps, etc... while you're in there! Replacing the rear motor mounts and rear shocks is very easy with the engine dropped about 6 inches also!
randywebb 07-11-2005 08:40 PM
see how these simple projects grow....
