Ventilation System Operation
There have been several questions about this recently, so I thought I would post the Official Factory Explanation:
Subject: RE: Heat Control FAQ for Pooschey Q: I just bought a Pooschey 911 and can't figure out how to make the heater work -- or the fresh air either. Can you help me? A: Sure, I can help you. The ventilation system requires that you operate 4 levers to make it work. 3 of the levers are on the dash, and the other is between the seats on newer Pooscheys there are 2 levers between the seats). The top lever on the dash actually does several different things (remember, it is a fiendish German device, just like the rest of the car). Pushing it to the middle opens the dust ports leading to the windshield (see below for operation of fogging machine and oil mist spray device). Pushing it to the right past the middle also activates the rattling noise-maker device. There are three loudness levels to choose from. Pushing the lever all the way to the left is used to jam the cable so unauthorized personnel cannot operate any of the devices above. The lever also enables the automatic heat exchanger signalling device -- when opening it spews rust particles on the windshield, you should replace the heat exchangers. Also, if opening it causes you to immediately turn blue or purple (not just hair, but skin color) and become unconscious, you (or your estate) should definitely replace the heat exchangers. The second lever from the top controls the lights on the White House Xmas tree. Move it to the middle to turn on the lights, and all the way to the right to fire 4500 Megatons of Nukes at Iraq. The bottom lever on the dash is used to replace the windshield when it becomes scratched or pitted with rock chips. It also determines how much hot air goes to your feet as opposed to your head. For example, let's say the engine is completely warmed up and the hot air is burning your feet. If it's a cold day, you can flip the lever to the other side and shoot hot air onto the windshield so it cracks and shatters. Then call your insurance company (you do have insurance, don't you?) The lever between the seats controls the oil mist spray device. When the engine is warmed up, this lever allows you to blow oil mist into the passenger cabin. Using the top dash lever lets you select whether you want the oil mist to coat the inside of the windshield or to just circulate around your feet. On a newer Pooschey, you have 2 levers on the floor between the seats. The left hand lever lets you open the left side vents which are aimed so they burn the feet of the person in the right hand seat, and the right hand lever lets you open the right side vents which are aimed so they burn the feet of the person in the left hand seat. Of course, each lever will also burn just the tops of the feet of the person in the other seat. If you are driving in the rain (or even stopped in the rain after the car has broken down), these levers also let you spray a fog of water vapor on the windshield, so no one can see in or out of the car -- sort of like privacy glass.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Detached Member
That's great!
I've got a rotary switch thing between the seats and when I turn it, it makes a whirrling sound, When you turn it to the first setting the soles of your shoes melt. I haven't tried turning it to 10 yet.
Hugh |
I was wrong then. I told everyone that middle lever was the suicide switch. One push to the side and you get the same benefit you would had you routed the hose from the exhaust directly to the cabin.
Sean '77 911S Cab Conversion |
The rotary switch was added to the newer cars after the demise of the swinging 70's. It is known as the Sexual Assist Device. The whirring you hear is the faint remnant of its original vibratory function.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off Last edited by randywebb; 07-12-2005 at 05:10 PM.. |
Re: Ventilation System Operation
Porsche Junky
I just spit a mouthfull of perfectly good Crown Royal all over my keyboard......
Help Fix My Heater Adjustment
Any idea how I can get it working correctly? Gordo
Don "Gordo" Gordon '83 911SC Targa |
I thought the levers between the seats were there to provide the spark in the engine compartment to ignite the gasoline fumes.
76/3.0 tarcabvertible 64 corvette conv. 72 Alfa GTV 79 Jeep Cherokee Chief |
Gordo - you can't tell anymore. We're pretty much just moving rubble back and forth now over there.
Thanks for the post, Randy. That saves me a bunch of time because I thought mine was broken...seems to be working to spec.
Looking forward to future articles on AC operation, transmission shifter, oil pressure gauge, oil level gauge, valve adjustment, spare tire deflation... You made my day, thanks.
David 83 SC 86 944 Turbo 73 914 1.7 (Chargrilled) 73 914 2.0 (Sold) |
Oddly enough, I just had the weirdest experience. For me, the 911 is normally a "special" car. This week, a friend was in town, and I had to loan him my Honda, so I spent the whole week driving the 911. ... But this morning, I'm back in the Honda, and I reached instinctively for the damper controls between the seat, and instinctively pushed all the levers to the right to fire up the defrost. "Stupid Japanese, why couldn't they just install separate fans for hot and fresh air! @#$@..."
![]() Dan
'86 911 (RIP March '05) '17 Subaru CrossTrek '99 911 (Adopt an unloved 996 from your local shelter today!) |
rofl.
I searched for info on heater controls, found this thread, and thought.. great, I'd better read this before I bother printing it out for reference ! Excellent explanation.
1975 911 2.7 Coupe |
every full change of seasons i have to re-learn how to work the damn things. i'd rather watch a full hour of reality television than have to go through the learning curve again..again.
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
Designer King
At least the owner pronounced it correctly: Pooschey, not Poosch.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
