Porsche80's Avatar
Question Another CC Servo ?
I need someone to confirm 2 things
1. If you disconnect the CC electrical connector on the servo and then in turn with an ohm meter, ohm out each of the 2 pins on the servo with one of the probes attached to ground. Does the meter show a short?
2. If you move the throttle (at engine) does the cc cable easily move in/out of the servo?
C
C
1980 911SC
Old 07-13-2005, 05:54 PM
