Thread for removing AAR
Hi guys,
Looking for a thread related to removing the auxiliary air regulator. Specifically on how to remove, what needs taken off to get to it. 76 911s Looking thru archives right now!!! |
IIRC, it's just held on by a couple of 6 mm Allen heads to intake runner #5 or 6. Just undo these, unplug the electrical connector, and loosen the two hose clamps on either end and you're done. HTH,
ianc |
Thanks for the feedback, back to the garage!
Is there anything thats needs to be moved out of the way prior to unscrewing the 6mm
Possibly the A\C compressor, but mine's been gone so long I can't remember... Just locate the part and it should be pretty obvious what to do...
ianc |
You are talking about removing and replacing? If not you've got a big air leak to deal with.
| All times are GMT -8. The time now is 07:00 PM. |
