jimi_c's Avatar
Stubborn Bolt
I'm trying to install a child seat in the back of an 85 carrera. I really need to remove the the backrest of the seat and the hinge bolt won't turn - is there any method you can recommend for getting it "un-stuck". Any help would be appreciated.
Cory H
85 Carrera
Old 07-18-2005, 04:20 AM
Cory is it a bolt or a slotted screw. My car 73.5 has a slotted screw head on out sides of car. The inner is simply a pin that the backrest slides on. Sorry for the Eyebolt mis-count. Try hitting the bolt/screw with some wd-40. Give a call if you want I will be on the road today.
Dave
Gemini Blue 73.5 911 T Sold
1994 C4 Widebody Sold
Old 07-18-2005, 04:55 AM
jimi_c's Avatar
It's a slotted crew, looks like it might have a lock washer on it, but I can't be sure - I tried WD-40, but no luck.
Cory H
85 Carrera
Old 07-18-2005, 07:16 AM
pwd72s's Avatar
PB BLASTER! MUCH better than WD 40. You can find it at most of the chain auto parts stores. Largest screwdriver you have to fit the slot, put a wrench on the screwdriver for more leverage...OR...Sears & Snap-On both sell sockets with a screwdriver tip.
Old 07-18-2005, 09:01 AM
