Well I got the engine out of the car. I was cleaning up the top of the engine when I noticed a washer in the intake, right behind the valve. I had a a vacum on hand, so I tried to suck it up. Huge mistake!!!!By the way I payed 5750, US, for the 911 sc, not bad
Anyway, The washer was nowhere to be found in the vacum. So I thinks that it dropped into the cylinder. I dont really want to take the entire valve housing off. I was thinking to flip the engine over and maybe blowing some compressed air in there, Any coments would be greatly appriciated. |
Virginia Rocks!
Someone suggested to me once to tape a small gas hose to the vacuum and stick it into the cylinder. Leave the vac on and pull out the hose - should be stuck to the end.
Good luck!!
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
Get one of those magnet's on a flex handle and go through the plug hole, if it will fit through the hole.
Also check the vacuum hose. It might have got hung up in there.
Can a borescope be rented? The upside down thing sounds reasonable. And, I agree about double checking the vacuum, but you are probably right. The washer made its way down inside. Too bad the valve was open. Otherwise, this would be nothing.
Irrationally exuberant
Vacuum + gas vapor => gas vapor going through electric (sparky sparky) vacuum motor. Pop goes the vacuum.
Or so I've heard... -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
tipping the engine sideways on an engine stand makes it easier. a stick magnet should get it though. carefully turn the crank to see if you get any resistance will tell you if it's in there. the piston will push it to the top so you might be able to see it past the open valve. you can actually open the valve farther by cranking in the adjustment screw until the spring coilbinds. then readjust when you're done of course.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 07-13-2005 at 06:46 PM.. |
Thanks guys,
I will take out the plug and try the mag. cheers |
It's not really a bad boo boo unless you started it with the washer in there. Don't ask how I know.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Take the borescope from your doctor.
1972 911T 1991 Mazda RX-7 Turbo II Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life! |
Registered Cruiser
"Vacuum + gas vapor => gas vapor going through electric (sparky sparky) vacuum motor. Pop goes the vacuum.
Or so I've heard..." When I was about 15 and even dumber than I am now, I siphoned gas out of my dads car this way and totally destroyed the vacuum and the paint below the gas door. Also had to remove 5" plastic shard from my leg after vacuum blasted apart. Luckily I didn't blow up the car.
87' Carmine Red Carrera - Keeper 82' Silver SC - Sold 79' Gran Prix White SC - Sold 05' Black C2S - Daily driver I have never really completely understood anything. |
That was on mythbusters last week - busted ! They ahd to do pretty extensive mods to the vaccuum to get it to blow !!
Registered Cruiser
Missed that episode - did they actually get gas in the vacuum or just fumes?
They did both, gas and fumes. They used primarily shop vacs. Apparently the newer ones are designed to keep the motor away from the materials being vacuumed. It was a fun one to watch.
'86 911 targa '04 MB 230K Sport (daily) |
Damn I missed that show.
When you flip it over have someone watch so they can help see that it does hit the floor. I did the flip thing and didn't hear it hit the floor. I started to panic until I just happened to notice that it rolled clear across the garage floor.
Thanks, Mike When I was a kid, I didn't want a stupid pony, I wanted a PORSCHE. 1970 911T Coupe, 1979 911SC Targa Euro, 1971 Honda CT70 HK Trail 70 (the ultimate in two wheeled transportation) |
