Input, Spring plate angle on my '69
I will be installing the rear suspension on my '69 n the next few weeks. I'll be putting factory adjustable spring plates with aluminun arms, etc. Thom & Wil's calculator says 29 to 30 degrees (based on 2,200 lb.) The car till have 24mm (24.1 mm?) torsion bars. It will be running a 2.7L, 915 and Webers - no AC. Anybody out there who has experience with a similar car & setup who can give a little input or confirmation?
ThanX
Marv Evans '69 911E |
I've found the calculator to be very accurate; I just installed 31mm torsion bars and other than some adjustments for corner balancing, it was spot on @ 17 degrees.
The important thing is to get the weight right.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Bird. It's the word...
Yep, found the calculator great. I just recently upped my 24mm to 27mm - I personally found the 24mm too light when I dropped my 2.7 in. I found the extra torque of the engine would cause the car to squat too much.
John Forcier Current: 68L 2.0 Hotrod - build underway |
