82 911SC First Porsche Oil Leak
I am happy with my car, but not the oil leak. Zero drips and just a tiny amount of seep where present on initial inspection and following three extended test drives. This car was extremely dry, definitely a positive in my desicion to purchase. During my drive home home, at a fuel stop, I added 1 quart of oil. When I got home my "dry" engine was dripping oil from the center low spot of the case. Prior to adding the quart, checked at idle, hot, level ground the the oil level was 1/4 inch above the lower dots. As I used up that quart (I love driving this car and often!) the engine seems to start to dry up agian, or at least not drip as much. My last oil addition produced even faster dripping. I added, as a test, 1 quart taking the level to 1/4 inch above the upper two dots on the dipstick, when I got home I could watch oil drip drip drip off the center low spot of the engine. As I am using up this quart, the drip rate is again diminishing.
Thanks to this board, I have already gained free horse power by adjusting the throttle linkage to open all the way, big jump in power. I also just replaced my forward shift bushings and added a WEVO coupler to improve, dramatically, the quality of the my gear changes.
Do you have ideas for me about about how to attack the source of my oil leak?
Old 07-17-2005, 07:42 AM
Brother's Avatar
Wayne's 101 Projects book has a chapter on hunting down oil leaks.
Paul
1980 911SC Targa - Sold
1972 914 - Sold
Old 07-17-2005, 07:58 AM
Original Owner
tsuter's Avatar
Re: 82 911SC First Porsche Oil Leak
Overfilling is an excellent way to create oil leaks. Why are you overfilling???
Try 1/2 over...you'll have oil oozing out all over.
edit: anything above the lower dots is fine. no reason to add.
tsuter
78 911SC Turbo Targa
Thaaaats Right!!
Old 07-17-2005, 08:46 AM
Location: the bluest city in the bluest county in the bluest state by the bluest ocean...did I mention the blue skies???
I usually run @ 1/2 inch BELOW the upper marks on the dipstick...to avoid overfill/ overspill. There's over 11 quarts running around in there so staying a bit under the top is not going to starve the oil supply. Oh, how I wish I only had one little leak....
Greg....PCA, 356 Registry, 912 Registry
1977 911S Targa with 3.2...1960 T-5 coupe
1968 912 coupe, that's 32 P-cars, so far...
1990 Chevy 4x4 2500 pickup (with 255K & still rockin')
Old 07-17-2005, 08:56 AM
Nitrometano's Avatar
Congratulations, your Porsche becomes a man.
1972 911T
1991 Mazda RX-7 Turbo II
Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life!
Old 07-17-2005, 09:17 AM
It dripped no oil at the bottom of the the fill range (just above the lower marks, quantity gage on bottom and not moving. It started dripping some oil with with my first oil addition (level 1/4 inch below the upper marks, quantity gage in the middle). It dripped oil at a faster rate when refilled to 1/4 inch above the upper marks (guage near top).
My thought was the leak was asscociated directly with how much oil was in the tank. I did not intend to fill it past the upper marks. I would not think this extra amount above the upper marks would induce/create the leak. It started leaking when filled to a level between the marks.
Maybe the leak is unrelated to adding oil, and I developed a previously unknown leak during my 70 mile drive home. It just seems the rate of this leak is directly proportional to the amount of oil in the tank.
Old 07-17-2005, 12:35 PM
