Compression Test results.
Jimmy from MobileWrks came over last Saturday to perform a compression test on my 83 911. Test results show the following:
#1 = 165 #2 = 164 #3 = 165 #4 = 164 #5 = 165 #6 = 164 Just to compare to other SC's, can you show me what your compression readings were on your car? What is the ideal result? My friends 1980 SC measured at around 123-128.
Carl, |
WOW Carl,
Those are as close as can be! I don't know what they SHOULD read, but I do know that having them so close is a good thing. Unless your whole engine is falling apart at exactly the same rate ![]() Looks great! -Chris
1987 Guards Red Targa (sold) 2006 Toyota Tundra DC 4x4, the "man-e-van" 1998 CR500 Well on the fringe...... |
Those are just fine.
Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
My numbers on my 85 RoW came in 4 months ago between 190 and 200. However my compression is higher in the RoW and that might make the difference. Not sure. Little variation is good, as cbeers said.
140K miles
1: 170/5% 2: 175/4% 3: They can't get the plug out !!!! 4: 175/4% 5: 173/5% 6: 170/5%
Doug Andrews 1982 911SC Targa 2008 Silverado Duramax 3/4 ton 2004 Armada 1999 Honda XR400 |
The %ages, Are these Leak down test results?
Carl, |
Yes they are. Just had it done this week.
When I had my '81 SC PPI'd it came in at 165psi accross the board. The mechanic said "good as new".
Doug,
Stuck plug? For how long? It has to come out sometime right? Also, I see you have a thumper in your stable. Do you ride often? Where? You can PM or email so we don't highjack Carl's thread ![]() cbeers@appsig.com -Chris
GOT TURBO..
"doug" i can get it out.... the longer you wait, worse your car will rumn.. like bitting a apple with one front tooth,...LOL
I think there is much variation in the individual gauges in individual shops so it's the variation between each cyclinder that is critical. Given your figures are within 1 point of each other it reads perfectly!
On that note mine are all between 145 and 150. Comments? Simon
85' Carrera 3.2 02' Mazda MX5 |
Location: the bluest city in the bluest county in the bluest state by the bluest ocean...did I mention the blue skies???
150 thru 155...
'75 2.7 CIS with unknown mileage & very complete rebuild done in '89 with "euro" P&C's...( I fixed the odo after I bought the car last year, but the orig. owner had not...for 12 years....DOH!!!)
Greg....PCA, 356 Registry, 912 Registry 1977 911S Targa with 3.2...1960 T-5 coupe 1968 912 coupe, that's 32 P-cars, so far... 1990 Chevy 4x4 2500 pickup (with 255K & still rockin') |
