-   -   Looking for airflow sensor boot (http://forums.pelicanparts.com/porsche-911-technical-forum/231782-looking-airflow-sensor-boot.html)
gliderguy 07-18-2005 07:09 PM
Its all about the boot
Well I wanted to say thankyou to anyone who responded to my questions and how fact-filled some of the old threads were. I have been "hunting" down a warm high idle and have found a crack on the backside of my airflow sensor boot. Anyone have one, in good shape, they would like to part with?
Just felt like inserting the pic
http://forums.pelicanparts.com/uploa...1121738658.jpg http://forums.pelicanparts.com/uploa...1121738954.jpg Thats me a 3000 feet!!
gliderguy 07-18-2005 07:29 PM
bump
Are they hard to find used?
gliderguy 07-18-2005 09:27 PM
bump
no replies?
RoninLB 07-18-2005 09:37 PM
as per pn 930 110 358 03
Part Number Search:
Description Part Number Price More Info
Air Flow Sensor Boot, 911 (1975-77)
H-110-358-03 $69.45
stlrj 07-19-2005 12:51 PM
Meanwhile, how about sealing the crack with some silcone sealer to see if that's your problem. It might do the trick and since it's hidden in back where you can't see it...might just leave well enough alone.
Otherwise you might be wasting precious time and moolah while the real culprit continues lurking somewhere inside your engine.
gliderguy 07-19-2005 01:10 PM
Thought about that! Wasnt sure if heat would be a issue with sealant. Should be ok?
stlrj 07-19-2005 03:24 PM
I've used it on ignition cable boots to prevent arcing and it gets much hotter on the plug connectors than it would ever get on top of your engine.
Joe
