CIS Idle Speed and Mixture Setting Without an Analyzer
This came up in a thread about CIS idle mixture, idle speed and mixture checking w/o a gas analyzer. So I figure I’d give it a separate thread.
Someone asked about what I call the “field test” for idle mixture. They questioned the method and seem a bit confused about how it works and what it can tell the tuner. This is not something new; it’s been discussed before. As a matter of fact, it may have been Dorki Charlie’s post that I recall seeing a long time ago. Prior to that I just used the “over rich” or “over lean” screw settings (turning it until the car gets upset then back off) method to set mixture w/o an analyzer. Here goes…. The air meter does not actually meter when the car is idling. The throttle bypass is technically the only way for air to get into the engine. Realistically, there are “leaks” that augment the bypass. There are internal and external leaks. Some cars have small leaks, some not so small, and the idle setting is often times compromised to make a car idle well with the larger than usual leaks. The compromise can show up in a drop in idle speed or a hang up in idle speed (e.g. when you come to a stop sign and the car wants to stall or the idle won’t drop to 900 or 1000 RPM. There can be other causes of the two symptoms, but more often than not the system setting is compromised) EDIT: Regarding the above paragraph....(and pulled from page 2) You are correct Jim. Air does have to go through the air meter housing to get to the throttle. There is enough differential across the air plate to move the plate just enough to raise the plunger (and break the contact with the switch on the back of the meter housing) in the fuel distributor. Fine adjustment of the plunger height is then performed with the idle adjustment screw. My state of mind during that initial post was to conclude that the plate-venturi (meter) is not metering, because the plate is still within the throat of the venturi. But that was a poor conclusion on my part. A portion of the plate (furthest from the fulcrum) does clear the throat, teetering on that ragged edge where the differential pressure holds it. The throttle bypass changes the flow rate around the throttle plate at idle, which inturn affects the differential pressure across the air plate (increase flow---increase differential), determining its height. Adjusting the throttle bypass in conjunction with the idle mixture screw achieves acceptable idle mixture and speed. So yes, it was misleading. I hope the above (and your post) clears it up and prevents anyone from going down a wrong path. End edit So! While at idle and you are adjusting the idle mixture screw, you are ONLY affecting the AFR at idle. Reducing the bypass thus richens the idle AFR because you are reducing the air (disproportionately to the fuel-edit) in the air-to-fuel ratio at idle so you must also reduce the fuel! When you turn the idle mixture screw, you are changing the height of the fuel plunger, not the meter plate (plate height is determined by the flow controlled mostly by the bypass screw at idle-edit)! You haven’t changed anything that will affect the volume of air that drawn into the engine. The fuel plunger rides on a secondary arm of the air meter plate lever. That secondary arm’s angle can be changed relative to the air plate’s lever. The meter plate height is set with the stop screw on the spring under it. The field air plate lift test is just a quick and dirty way to check if you are rich or lean…You can even pull down on the plate. By pushing up or pulling down on the plate slightly, you are in effect changing the idle mixture. You are raising or lowering the fuel plunger. STOP! Don’t ask about the air meter or change in flow. Stop! Think about the throttle body? Is the throttle body valve (butterfly) mechanically connected to the air plate? NO! If you thought yes, you need to step away from your CIS….just put the 3mm Allen wrench down and walk away. Go call a friend and ask for help…heck call me! My cell phone has a few minutes between rings. You are only moving the air plate a millimeter or two with this test. As a matter of fact, you can move the plate enough to stall the car by giving it too much gas when you push up on the plate…lets call that a “rich stall,” because you created too rich of a mixture in the engine. If you move the air plate up slightly with a resulting rough or surge, you are closer to the rich extreme. If you have a 3mm Allen wrench handy, you can turn the mixture screw counter-clockwise to lean it out a little, maybe 1/8 of a turn, then repeat. To get it just right, you’ll have to develop a touch and maybe even a sense of smell. To test for lean, you can pull down on the arm slightly and get the opposite effect of the rich test. That’s it! That’s all there is to it. Understanding what’s happening when you make adjustment is the key. I often tell folks to read up on the individual components. With out doing that first, one can’t understand how the CIS (S=system!) works. System…if you don’t understand how it all works as a system, you’ll get something out of whack, and then it’ll be a trial and error fest when you go looking for help. Understanding the system will also minimize the expensive “parts swap” trouble shooting that some folks have gone through. As I hinted at the beginning, you can also test for rich or lean by changing the plunger height using the idle mixture adjustment screw. If you turn the screw clockwise until the engine starts to stumble or surge you are getting too rich. If you want to run rich, say with advance timing, turn the screw back 1/8 or ¼ turn, race the engine and see if you idle is acceptable. If there is no surging and the idle is where you want it, you’ll be OK…rich, but OK. To test for the lean extreme you do the opposite. Turn the screw counter-clockwise until you stumble or surge. If you make a mental not of how many turns of the screw there are between too rich and too lean, you can then put the mixture right in the middle! This brings us to idle speed and how to lower it. If you paid attention, you’ll know that you can raise or lower you idle speed by changing both the bypass screw setting AND the idle mixture. You have to adjust both, not just one. You can adjust one at a time, and you may find that you will create a lean or rich surge. (That is actually the way you should do it if you are not confident of what you are doing) If you are closing the bypass, and the engine surges, then reduce the fuel. Get the idea? Air and fuel combine to produce energy when ignited. Often a high idle speed is the complaint. So reduce air and fuel to reduce the idle speed. Be wary that you do not have a problem somewhere else which is causing your high idle. Always make a mental note of the amount of your adjustments so you can return it to the “as-found” setting if you booger things up. Analyzer Note: I've made adjustments on my car (w/ a '78 CIS engine) using a 4-gas analyzer, and I think a good tuner should be able to make a good mixture adjustment without the CO tester that everyone thinks is so indispensible. The CO tester only tells you one thing. Sure it's nice to have, but unless you have a 4-gas or 5-gas, you'll just not making all the right changes. Even with a 4-gas I had to make adjustments to the ignition, bypass and mixture screw in order to get the critical EPA components (pollutant) low enough to pass! A friend recently bought a Euro '78 SC. I tuned it for him to make it a little more peppy. Even with the "richer than before" setting on his car, he passed the Illinois EPA test. I'm not saying I can replace a gas analyzer, but when the CIS is operating well, you can make adjustments without a CO analyzer and still be pretty damn close to perfect! Now the disclaimer: Don’t go diving into the engine bay and start turning screws. As I said before, learn the components and understand the system! Besides, I’m operating on 2 hours of sleep after a long night in the garage. So if you really screw something up or if I made a mistake or forgot something…blame it on the stubborn bolt I had to wrestle with last night, thus turning my 3 hour session in the garage into a 6 hour swearing session! |
Outstanding, Souk. You're the man.
When I was at your house last you just tuned by sniffing the tail pipe exhaust gas. Or was that for some other purpose?? :)
Me, I use a canary. They're cheap and don't require any wires |
:) Oh no Thad...my nose is only calibrated to tell me if it's too rich...and too too rich...which is accompanied by watery eyes :D For on the fly AFR monitoring, I tie the neighbor's dog to the bumper. If I here him choking...I'm too rich :D Them yippy yappy poodles can really run after they find out how bad road rash can be!
michigan: glad you got something out of it....usually my ramblings are just that....ramblings :) |
For a guy who is just STARTING to grasp some of this, and who has no few tools yet (no pressure gauges, etc), this stuff is priceless.
Thanks Souk. |
Per usual, bravo brotha!
nice souk. i learned a FEW things!
have you ever set mixture using a dwell meter and the lambda duty cycle? i read about it all the time, but i can't make sense of it. like the first damn step: "find duty cycle attachment point." ???? :D |
Never Cliff....but I have a wideband O2 sensor and logger. And I'd disable the lambda circuit on the 80-83 SC's anyhow :D
Thanks Souk, good stuff.
Good reminder on understanding the components first and that all parts are working with no vacuum leak. I have done the AFR without an analizer for years. Go cw until idle gets rough (Rich), go ccw until coughing (Lean) then set the mixture screw in the middle. It's between the idle speed (Large, slotted by-pass screw) and mixture control (3mm Allen screw) You may want to edit slightly: Quote: If you want to run rich, say with advance timing, turn the screw back 1/8 or ¼ turn, race the engine and see if you idle is acceptable. If there is no surging and the idle is where you want it, you’ll be OK…rich, but OK. That should be: turn the screw forward (cw) ......No? |
Although i have a pretty darn good understanding of ther CIS system, I have one question I hope you or someone can answer:
I've read somewhere in my manuals or books (factory, haynes, CIS books, etc) that the mixture adjustment screw should always be adjusted from lean to rich. In other words, to lean it out, you need to go past the desired point, and then back up in the "rich direction. WHY?!!!!! I don't quite get that. |
Souk,
this is great. I've been using a variety of methods over they years and have found that you can get it running pretty well with your methods. Question, are there certain telltales of rich vs lean running. I.e. when you lift off the throttle and the revs drop down really low before returning to idle -- is this an indicator of too rich or lean. Or when you stamp on the gas, if you get a split second of hesitation before the car picks up, is this an indication of too rich... There seem to be a number of these sort of telltales which I forget right now. Finally, the CIS system has components which affect idle vs running mixture. The WUR. This will use vacuum (in certain years/models) to lean the mixture at idle and richen at WOT. Can this throw off your mixture adjustments, such that checking for acceptable idle is not the best way to check for overall mixture? |
Gunter, I didn't go back to read the first post (yeah I'm lazy), but I believe I was speaking about going to the point of surging rich, then backing off. Basically, running as rich as you can w/o surging...only in the case that the timing is advanced to 35 degs, and in the summer. We're looking for predetonation protection, with no regard for mileage or exhaust quality. ;)
Sammy, most things are better adjusted from low to high. Like a regulator (air, fuel, what ever fluid you want to consider) setpoint. Making the idle mixture adjustment causes the plunger to go up or down while the air meter plate is fixed. So the rising action is better as you are "extending" all factors....I ain't to good at articulating what's in my head unless I have a few Guinness in me, so use your imagination. :D |
This thread is a worthy addition to my favorites list.
Chris, we're talking about idle mixture. I see what you're getting at though, and it's gonna take me some time to address soem of the other factors that affect CIS operation....not while I'm at the office though...too many distractions.
It comes down to understanding how the components operate and how they work together....... |
Chris:
Quote: Question, are there certain telltales of rich vs lean running. I.e. when you lift off the throttle and the revs drop down really low before returning to idle -- is this an indicator of too rich or lean. Or when you stamp on the gas, if you get a split second of hesitation before the car picks up, is this an indication of too rich... There seem to be a number of these sort of telltales which I forget right now. I had exactly what you are describing, RPM dip too low when lifting and slight hesitation when accellerating. It was annoying. Had to adjust mix and idle speed several times minutely; I suspect that it was a rich condition that caused the symptoms. But..............let Souk chew on that one. :D |
Souk
Why would you disable the Lambada on a 80-83SC - And after you do would I need to adjust the mixture. Thanks |
This should be a sticky..
Re: CIS Idle Speed and Mixture Setting Without an Analyzer
I'm a little late catching up to this thread, (this fall).
Hi Steve! Charlie showed me this method last spring and I believe it is a great start. I have been learning and tweeking my system for the last few years and learn more as time goes on. I have an 83 Row cab. This is the same k-basic system (no brain) as the 78-79. I recently passed MD emissions without a cat. I got a little time on a 3 or 4 gas anylizer at a gas station. I had no problem getting the co down below the max but if I got that down the hydrocarbons went up. I was about to give up when I found that If I raised the idle up to about 1100 they both fell below the limits. I don't recall the hydrocarbon # but co was at .89. The car runs better than I expected on this lean mixture. With emissions behind me I began flirting with trying to find the right mixture for performance. I barrowed a LM1 from Kurt who is another dorki and PCA tech chair. My quest is to forget about idle mixture and consentrate on achieving the best mix for the engine's power band. I have been running arround for the last few days with the LM1 hooked up and watching the "System" in action. Although I don't have the rpm sensor. I recorded several sessions and tried to remember what happened during those runs. BTW, I did richen the mixture ever so slightly since the emissions test. I am also just learning how and what this new toy and the graphs are telling me. Idle is currently hovering arround 14:1 Light cruise is arround 13.5 -14 Decellerating with the engine in gear the ratio goes up and I've seen on some occations 16 or 17:1 (Possible air leak?) While recording acceleration runs the ratio progressivly gets richer and you can actually see the effect when the air flow caused the plate to get to the steep part of the cone. I have seen and recorded mixtures going from about 12:1 @ 4500 rpm going close to 10:1 at 6000 rpm. I am loving this toy and the fact that it is confirming what I have read and understand about the CIS system in my car. I wish I could justify getting the AUX box and I would like to record the rpm, map, temp and control pressure. With this info I think I could possibly get closer to my quest. In the mean time I have a few questions to pose to those following this thread. (And I guess directed to those that have the k-basic system w/out lambda control) Observation, I am currently set at 14:1 which correlates to 1% Co on my graph. My little spec. book shows 1-2% for 82-83 row SC. 1st: what rpm band should I be tuning for? I can see the point at which porsche/bosch designed the cone to make the mixture richer. (I haven't pinpointed it exactly, but it's about 4000. 2nd: what is the max power mix? I've seen 12.6 - 13 is optimal. 3rd: It seems like the shape of the cone is creating a progressivly richer mixture as the rpm's go up. 4000-6000 at least. What's up with that? Is that designed on purpose? (detonation prevention with the 9.8 cr? 4th: I understand that too rich a mixture actually produces less power. How much is too much? Finally, the cut-away is great. One thing that is not mentioned is the little adjustment screws near where the 6 lines to the fuel injectors are connected. My assumption is that these are for equilizing the flow to the cylinders? PS I was recently on the LM-1 site and they are now selling a simplified system that can be used to just display the mixture on a gauge. No datalogging etc. F |
emac: disabling the O2 sensor dumbs down the CIS so you essentially have the operate like the earlier CIS. It allows you to run a little richer with more advanced timing.
Kaefer: the CIS is designed (via venturi design and fuel distributor design) to handle the other operating conditions. Set the idle and go. If you have issues after a properly set idle mixture...look elsewhere...ignition, decel valve AAV, AAR, vacuum, control pressure, fuel distributor, injectors, leaks..... Each of these should be address separately or rather understood seperately so you know what the results of their failure. This is a thread about idle adjustment with the assumption that all others are working properly. Something the manuals and tech references don't address is how they all operate together or more importantly how they DON'T operate together! The trouble shooting matrix that has been developed by the factory is good, but it doesn't contain enough detail/explanations. It's a good start, but as with as with systems that contain many components or sub-systems, it is difficult to cover it all in the matrix. One of these days, when I run out of projects, I may just write a tech manual on this stuff! |
Chris,
Re your descriptions: If the revs drop and then swing back up while the car is coming to a stop, your mixture is probably too rich. If you get a little hesitation when accelerating from a stop, like the engine is kind of "spooling up" before it pulls strongly, then the mixture is probably too lean. |
Sounds good to me.
Vash, the 'duty cycle attachment point' is a three pin cylindrical connector located on the left side of the engine bay near the CDI. It is black with a rubber boot covering the connector. There is a pretty bad picture of it on page 240-25 of Bentley. You want to connect the dwell meter to pin 2 (signal) and 3 (ground). My dwell meter reads in degrees, not duty cycle, so I have to convert: 30 deg. = 50% when the meter is set for 6 cylinders. After the engine is warm, you simply set the idle mixture and air bypass so that you get the correct idle speed and 50% duty cycle.
to be honest, not knowing any better, I read what everything did then I just tweaked mine like I would have a Holley carb and it runs well enough with a nice stable idle and starts easily. I think I got very very lucky because all of my components sat on a shelf for six months. The only issue i have is occassionally the WUR is a little cranky after sitting for a couple of days. It really seems like the control pressures are all over the place for a few minutes then everything stabilises and no problems again for a few weeks. I just blame it on 30 year old components and consider it part of the personality of the car.
On the duty cycle thing, my car doesnt have a lambda so I can not try this, but I have a low cost (around 30 bucks) digital multimeter which has a duty cycle function. Something to keep in mind for the guys who want to try that method because you can never have too many dmms :P Plus its an excuse to buy tools which is always good :D Again kudos to Souk, always great and informative stuff! |
Scott
I tried the duty cycle port adjustment thing with my dwell meter and did not get any reading with any of the pins. I did set it to 6 cyl. as I read on a post on rennlist but the meter did not regester anything. When I set my Vohm meter to m/amps I do get a reading but have no idea as to what to do. Go so angry I took the dwell meter back and got my money returned. |
Souk,
It almost seems CIS need its own section of board; there are so many questions posted. An expanded problem/solution matrix would be great if you ever got around to it. More telltales: Popping from intake/airbox (to lean?) Backfires from exhaust (too rich? or an air leak). Surging at idle (too rich?) Runs hot (too lean? can you get high temperatures form being too rich?) Black smoke from tailpipe (too rich?) White smoke from tailpipe (too rich?) These aren't problems my car exhibits, I'm just trying to get a bunch of the telltales I've experienced in the past verified and documented. |
Great info, I've been having idle problem for a while so I'll give this a go.
Thanks Souk |
Ahhh...it is that time of the year when minor adjustments will be needed. :) I'm glad the stuff I post are helpful. Good luck.
Souk,
I've read the initial post in the thread, and I need to raise the question about your statement that the airflow meter doesn't meter air at idle. The air flow meter/ fuel distributor doesn't allow any fuel out the injectors with the pump running, and the plate at rest, engine not yet started. It begins to inject fuel as soon as there is airflow past the sensor plate, so I don't know what else you could call this except for metering fuel at idle. Also, it's a bit misleading to say that the only way for air to get into the engine is via the throtlle bypass, as all the air that gets into the engine has to come thorugh the air flow sensor (unless there is an air leak). The air that bypasses the throttle has already gone through the airflow sensor. So even with a closed throtlle (at idle), air flow is pushing up the airflow plate. No intent to be critical, as I know you have a good grasp of the CIS, but I was thinking that someone new to CIS might be mislead by the way this was stated in the post. |
I know this might be non topic, but if you some of you are having high idle issues, it might not be a too rich condition. In fact it might not even be a AFR issue at all. The culprit could actually be the decel valve. Mine developed a leak from the back hose which was rubbing up against the throttle linkage and had rubbed through. My solution was to just remove and plug the lines. As for the idle mixture, I also have been following these methods Souk has outlined with great results.
Souk, any word on the wheels? :) |
My state of mind during that initial post was to conclude that the plate-venturi (meter) is not metering, because the plate is still within the throat of the venturi. But that was a poor conclusion on my part. A portion of the plate (furthest from the fulcrum) does clear the throat, teetering on that ragged edge where the differential pressure holds it. The throttle bypass changes the flow rate around the throttle plate at idle, which inturn affects the differential pressure across the air plate (increase flow---increase differential), determining its height. Adjusting the throttle bypass in conjunction with the idle mixture screw achieves acceptable idle mixture and speed. So yes, it was misleading. I hope the above (and your post) clears it up and prevents anyone from going down a wrong path. |
Hi all.. Im a complete newbie as far as working on porsches goes... In fact, I don't even own one.. This is a problem with my dad's car..
This topic seems relevant to the problem we're having with my dad's 1984 Targa.. Sorry if I should have posted this elsewhere. He was experiencing some rough idling and read in a book that you can adjust the idle mixture (I guess that's the one right above the intake box eh?).. Anyway, he had me see if I could find an allen wrench that would fit and eventually I found a 3mm that seemed to be working. He didn't tell me what I was adjusting, so I guess I assumed it wouldnt be something as important as mixture. What concerned me though, was that there was no 'clicking noise' that the book we were reading was explaining we'd hear while turning the allen wrench. We had the engine off while we were doing this. I turned it clockwise a few times and my dad tried to start the car... Started and immediately stalled, and thereafter it would only turn over. So then I guess he went crazy, took a wrench and was turning it with that. I told him I turned it clockwise so he should turn it counter clockwise, but Im not sure if he had the same interpretation of counter clockwise as I did. In any case, it turned it so many times in one direction that now the thing is stuck. Well, I guess my question is, is there some way I can visually inspect this thing and determine which way I need to back the idle mixture screw out to fix it? Or are we gonna have to order a new part, which I am guessing is gonna be somewhere in the 1000's of dollars since its a Porsche part? He went to bed muttering all sorts of words which shouldn't be said here. |
If it's an 84, I doubt if it is a CIS system. You might want to post a picture so everyone can confirm what you are working on and the screw you are playing with
As long as this thread has resurfaced..I have noticed that on the Jim Williams CIS site he suggests that when doing the push/pull method one should try for a slight increase in idle speed when the sensor plate is lifted. This seems to make more sense to me then having the rpm's drop. Any thoughts? I'm also wondering if anyone has ever checked the CO of their car after doing this 'rough AFR tuning' to see just where things actually are with this method.
Well it seems to me like the idle mixture setting isn't quite as important to fine tune - I'd be more concerned if I were leaning it out too much under higher revs.
Macel:
What engine is in this '84? '84 Carrera has a 3.2 with Motronic: No adjustment possible. If you were able to insert a 3mm Allen into the Fuel Distributor top to set mixture, it's a 2.7 or 3.0 liter with K-Jetronic. Without knowing what you were doing, with the engine stopped, why would anybody just "screw" around the adjustment screw until it gets stuck? Mixture is adjusted with the engine running and only if you know how; very small movements cw or ccw. Why not get a manual, like the Bentley, read and learn about these engines first before playing mechanic? To help you out with this, let us know what engine you have; you'll find the number below the fan post on the case like: 930/07 Unless your post is just a joke??? :) |
No to be honest, I know nothing about porsches and was just giving my dad a hand with this. Since he knows nothing about computers, Im here posing the question for him. I was literally just turning the wrenches he was telling me to turn while he was reading out of some book, so don't look at me!
Had I personally known what I know now about what this adjustment does, I would have certainly been more careful though. I err, will have to check exactly what engine it is when I get back home tonight. |
Sounds like you leaned it out too much for starting. Should you get it to start with this same setting you may melt the top of your pistons with extended use.
It's better to run a little too rich than too lean and idle setting too fast rather than too slow. If it is running way too rich, excessive gas will not combust and will mix with the oil which may ruin the piston rings from lack of lubercation. There are a bunch of little things which may prevent you from getting a proper mixture and idle setting, the WUR (warm up regulator) is just one of them. I'm in the process of fixing this on my CIS system. Could be shop time, don't bend over to pick up the soap. |
You stated that you have a 1984 911. If that is the case the engine bay should look similar to this: (Notice the air meter connected to the cone air filter)
http://forums.pelicanparts.com/uploa...1148933482.jpg |
If you have a 1984 but it has the CIS induction (I'm trying to find a picture of an engine bay), then someone swapped a 3.0 liter into the car which should have a 3.2 liter engine similar to the one I posted in the previous post).
I have never heard an idle mixture screw click. What ever book you and your dad are reading, put it down. (There is no one book that I have come across which puts all of CIS's concerns between its cover. So don't assume that book is the end all be all). Where are you? Maybe there is someone near you that can come give a hand. Don't be offended, but the skill level I sense of you and dad is not up to adjusting CIS. If you keep going forward you will end up costing yourselves a lot of time and money... |
| All times are GMT -8. The time now is 10:04 PM. |
