DG624's Avatar
Body Reinforcement for 911
My front lower body pannel and gas tank support are being replaced and I thought it was a good time to add additional seam welds to strengthen the front. Has anyone done this work and is it legal in Solo II and Porsche track events?
Old 06-07-2006, 10:56 AM
na2ub's Avatar
I assume you mean the "suspension pan" and gas tank support. I don't know about legalities, but I would doubt that additional seam welds will do much of anything, except make it harder to replace next time.
Doug
79 SC Targa w/ ITBs, 2004 Cayenne Turbo
Old 06-07-2006, 11:43 AM
DG624's Avatar
I was thinking this area is basiclly weak and has very little support. I have seen over track cars with extensive seam welds and suspension tower supports added. I can't weld so I thought that this would be good to do when the car is repaired. Short of a full cage there are only limited things possible.
Old 06-07-2006, 02:15 PM
PRO Motorsports
Tyson Schmidt's Avatar
While the gas tank is out for the pan replacement, I would seam-weld the rear corner braces. These are the ones normally hidden by the tank, and at the lower rear corners of the tank. That's a better place to gain stiffness.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 06-07-2006, 07:33 PM
DG624's Avatar
Tyson thanks for the info...I will tell the body shop.
Old 06-08-2006, 01:20 PM
