wahoofan's Avatar
k&n for a 2.4?
Will putting a K&N filter on my 2.4 mfi make any noticeable difference?
wahoofan
'72 911T Targa
Old 07-22-2005, 10:19 AM
efhughes3's Avatar
I'm subscribing, as I can't wait to see the replies to this one
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 07-22-2005, 11:12 AM
304065's Avatar
Only to your wallet.
If you are using the factory airbox, the MANN filter is fine. The great Roland Kunz once said that the same size filter was sufficient for a Mercedes 450SEL 6.9. Also, the K&N cylindrical filter isn't as good a fit as the MANN.
If you were thinking about dual K&N watershields, some say they actually reduce hp and torque on the dyno, some say they improve it. Again, unless you are racing (in which case you probably remove the air filter, as you're going to tear down the stock motor every three seasons anyway) it won't make a meaningful cost/benefit difference.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 07-22-2005, 11:37 AM
B D B D is offline
B D's Avatar
I found the opposite to be true on my air box and/or filters the K&N fit better. But now I have a better style K&N that is only open on one side and with a hose clamp attaches to the back of the snorkel. Before both filters were so loose in the air box they were useless.
68 911L
Old 07-22-2005, 11:55 AM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
I have used the K&N in my 2.4 for years. It fits perfectly but can't say it has any positive effect on HP.
Chris
73 911 E
Old 07-22-2005, 01:24 PM
